It is currently Sat Sep 26, 2026 5:43 am
Post Posted: Tue Dec 15, 2009 1:18 am
hey i got a 91 wt umm just wonding if any one knows y the 4wd light would not be working never has sence i have had it. and the interior lit did work but was dull as fuk and ideas?
2''lift 31's twin locked & 6.5s
Post Posted: Tue Dec 15, 2009 1:24 am
Loose earth connection maybe
Post Posted: Tue Dec 15, 2009 1:27 am
Bad switch or no switch mine dint have a switch check the connections etc
the door switches have a common earth problem could be the reason for a dull interior light
Post Posted: Tue Dec 15, 2009 1:29 am
were is the switch for the 4wd light? yeh might just put a new light set up in there led or sumthing
Post Posted: Tue Dec 15, 2009 1:44 am
Switch is right were the lever enter the transfer caase
Post Posted: Tue Dec 15, 2009 1:47 am
oh ok kool thanks
Post Posted: Tue Dec 15, 2009 2:30 am
My switch wire was cut a few weeks ago in the bush. at first the light stayed on all the time now its off. I found that the bulb in the dash had burnt out.
Post Posted: Tue Dec 15, 2009 2:36 am
yeah usually shitty switch or broken wire off the switch causes that
Post Posted: Tue Dec 15, 2009 2:41 am
koolies well it looks liek it coming out anyways so ill have a look
Post Posted: Tue Dec 15, 2009 3:45 am
x2
mine had a broken wire that would sometimes touch with the wires that were left on the case
Users browsing this forum: No registered users and 81 guests
