It is currently Sun Sep 27, 2026 11:13 am
Post Posted: Mon Dec 14, 2009 4:11 pm
:?: as above
thanks
Post Posted: Mon Dec 14, 2009 4:22 pm
1.3 carb, efi or twincamefi
1.6 carb or efi
Post Posted: Mon Dec 14, 2009 4:27 pm
1.6 carb or efi
1.3 carb to 1.6 carb
sorry
Post Posted: Mon Dec 14, 2009 5:56 pm
I have heard they fit. I have never done it.
Only difference it should be is the head height will be alittle taller.
Post Posted: Mon Dec 14, 2009 7:32 pm
1.6 carb or efi
sorry
Yes.
Post Posted: Mon Dec 14, 2009 7:54 pm
Thanks for the replies.
I thought they were the same. I cracked one pipe right through where 4 goes into one. can only weld where you can get to . :cry:
I think a flex joint would be a good idear straight after extractors. Any one else done that?
Vehicle: 07 vvt jimny
Post Posted: Mon Dec 14, 2009 11:22 pm
your crazy.... i like you :D but your crazy ha ha ha ha
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Mon Dec 14, 2009 11:53 pm
Have you not seen one? Here have a look
Meant to take the load off the extractors from the rest of exhaust.
http://cgi.ebay.com.au/NEW-2-STAINLESS- ... 2e91651dbf
Vehicle: '92 Sierra
Post Posted: Tue Dec 15, 2009 12:46 pm
Mine runs a flex joint. It helps me out because my system runs tight up against the body and chassis to get around a long range tank. I'd be surprised though if you cracked your headers due to the weight of the rest of your system. Theres a support not far back from where the headers join the pipe.
Post Posted: Tue Dec 15, 2009 2:48 pm
I hit something hard and it broke the first support (rubber mount) and cracked one pipe clean through. I reckon a flex joint may have prevented that. Gota sort out the front springs, way to rigid..
Users browsing this forum: No registered users and 46 guests
