http://auszookers.com/forum/
Do 1.3 extractors fit a 1.6
http://auszookers.com/forum/viewtopic.php?f=5&t=8629
Author:  squirezook [ Mon Dec 14, 2009 4:11 pm ]
Post subject:  Do 1.3 extractors fit a 1.6
:?: as above
thanks
Author:  BlueSuzy [ Mon Dec 14, 2009 4:22 pm ]
Post subject:  Re: Do 1.3 extractors fit a 1.6
1.3 carb, efi or twincamefi
1.6 carb or efi
Author:  squirezook [ Mon Dec 14, 2009 4:27 pm ]
1.6 carb or efi
1.3 carb to 1.6 carb
sorry
Author:  BlueSuzy [ Mon Dec 14, 2009 5:56 pm ]
I have heard they fit. I have never done it.
Only difference it should be is the head height will be alittle taller.
Author:  Fatzook [ Mon Dec 14, 2009 7:32 pm ]
1.6 carb or efi
sorry
Yes.
Author:  squirezook [ Mon Dec 14, 2009 7:54 pm ]
Thanks for the replies.
I thought they were the same. I cracked one pipe right through where 4 goes into one. can only weld where you can get to . :cry:
I think a flex joint would be a good idear straight after extractors. Any one else done that?
Author:  zuk85 [ Mon Dec 14, 2009 11:22 pm ]
your crazy.... i like you :D but your crazy ha ha ha ha
Author:  squirezook [ Mon Dec 14, 2009 11:53 pm ]
Have you not seen one? Here have a look
Meant to take the load off the extractors from the rest of exhaust.
http://cgi.ebay.com.au/NEW-2-STAINLESS- ... 2e91651dbf
Author:  Hybrid [ Tue Dec 15, 2009 12:46 pm ]
Mine runs a flex joint. It helps me out because my system runs tight up against the body and chassis to get around a long range tank. I'd be surprised though if you cracked your headers due to the weight of the rest of your system. Theres a support not far back from where the headers join the pipe.
Author:  squirezook [ Tue Dec 15, 2009 2:48 pm ]
I hit something hard and it broke the first support (rubber mount) and cracked one pipe clean through. I reckon a flex joint may have prevented that. Gota sort out the front springs, way to rigid..
