It is currently Sat Nov 14, 2026 10:11 pm
Post Posted: Sat Dec 19, 2009 7:15 am
Is there much difference is the location of the motor mounts in the 1L and the 1.3L of the year model?? Will a 1.3 bolt straight in being that it was the year of change over is what i am trying to ask and has anyone done it ?
Post Posted: Sat Dec 19, 2009 11:58 am
If yours is a Type 3 (with the all-grey plastic dash), then the chassis mounts are pre-drilled for F10A and G13A engine mounts. Have a look, there should be 3 holes on the mount pads of the chassis. Besides the actual rubber mount, you will also need the 1.3 chassis brackets.
You will also need a 1.3 gearbox as the bellhousing pattern is different between the 2 engines.
Post Posted: Sat Dec 19, 2009 5:04 pm
be careful here, i am putting in a swift gti engine, and nothing lines up from the old 1 litre. making all new chassis mounts. mine is a 85 cab on an 82 chassis F10a engine
Post Posted: Sun Dec 20, 2009 4:42 am
Yeh i would say mine is a type 3 then its has the three holes drilled on the pad. Thanks for your help looks like a conversion is on the cards now lol
Users browsing this forum: No registered users and 76 guests
