| motor mounts in 1985 sierra http://auszookers.com/forum/viewtopic.php?f=5&t=8732 |
| Author: | Droid265 [ Sat Dec 19, 2009 7:15 am ] |
| Post subject: | motor mounts in 1985 sierra |
Is there much difference is the location of the motor mounts in the 1L and the 1.3L of the year model?? Will a 1.3 bolt straight in being that it was the year of change over is what i am trying to ask and has anyone done it ? |
| Author: | 303zuke [ Sat Dec 19, 2009 11:58 am ] |
| Post subject: | Re: motor mounts in 1985 sierra |
If yours is a Type 3 (with the all-grey plastic dash), then the chassis mounts are pre-drilled for F10A and G13A engine mounts. Have a look, there should be 3 holes on the mount pads of the chassis. Besides the actual rubber mount, you will also need the 1.3 chassis brackets. You will also need a 1.3 gearbox as the bellhousing pattern is different between the 2 engines. |
| Author: | Jamie [ Sat Dec 19, 2009 5:04 pm ] |
be careful here, i am putting in a swift gti engine, and nothing lines up from the old 1 litre. making all new chassis mounts. mine is a 85 cab on an 82 chassis F10a engine |
| Author: | Droid265 [ Sun Dec 20, 2009 4:42 am ] |
Yeh i would say mine is a type 3 then its has the three holes drilled on the pad. Thanks for your help looks like a conversion is on the cards now lol |
