It is currently Sat Nov 14, 2026 7:24 pm
Vehicle: 95 Sierra Soft top
Post Posted: Tue Dec 15, 2009 10:45 pm
Hey guys did a search not much come up for what i needed, but like i said in the Subject
One day my 95 sierra soft top just started idleing very high and drinking alot of petrol,
its starting to do my head in, every time at the lights sitting on 2500rpms its just GRRRRRRRRRRRR :evil: Not happy jan
But any help would be good guys
Keith :wink:
Post Posted: Tue Dec 15, 2009 10:57 pm
Checked the vacuum tubes? I had one of mine stuck when I did the clutch cable :)
1990 SWB Vitara
1997 Sierra
1991 Sierra *RIP 7/0
Post Posted: Tue Dec 15, 2009 11:07 pm
Choke stuck on..
Post Posted: Tue Dec 15, 2009 11:25 pm
Where can i find the choke and which vaccum tubes am i looking for ??
Post Posted: Wed Dec 16, 2009 1:04 pm
So cant anyone help me ???
Post Posted: Wed Dec 16, 2009 1:13 pm
top up your coolant, then check the 2 little water hoses coming out the back of the carb are getting hot
Post Posted: Fri Dec 18, 2009 4:25 am
yup, top it up and the over follow bottels as well, and got it to running temp, the 2 hoses your talking about are the 2 coming from at the back yeah, one gos to the block yeah ??
Well there the ons i looked at and one was pretty hot and the one going to the block wasnt hot, whats that mean ??? :?
Post Posted: Fri Dec 18, 2009 4:28 am
Means there's a blockage. If the coolant doesn't flow through there, the choke won't know when the engine has warmed up, so the choke will never open.
I want my old sig back :(
Post Posted: Fri Dec 18, 2009 8:13 pm
I see now, hmmmmmmmm now i do i unblock this blockage, is it much work or would it be better of if a mechanic did it ??
Post Posted: Fri Dec 18, 2009 8:32 pm
Well, first step would be to remove the hoses from the carby and see if you can see/get the blockage out. Next step would probably be to stick a bit of wire in there and wiggle it around to try and dislodge the crap in there, I would say...
Post Posted: Fri Dec 18, 2009 9:45 pm
that bit is called the waxstat, if tis blocked chances are its corroded up, dont poke too hard but expect to be buying a new one
Vehicle: SJ80, SE416
Post Posted: Fri Dec 18, 2009 10:31 pm
Before you check the choke itself for a blockage, check your hoses too by trying to pour some water down them. The original ones on mine perished from the inside out, and blocked themselves up. That hose is only a few bucks a metre.
Post Posted: Fri Dec 18, 2009 10:43 pm
Do you mean a new carby or just the hoses ???
Post Posted: Fri Dec 18, 2009 11:15 pm
A new waxstat....
Post Posted: Sat Dec 19, 2009 2:41 am
Ben_Sierra wrote:
A new waxstat....
How much are they and would i be able to get one from bursons brand new ??
Cheers guys thanks for the help as well :wink:
Post Posted: Sun Dec 20, 2009 8:16 pm
Ok I cleaned out the hoses and they where blocked with mud and shit, i did my best to clean them out with wire and water, but still reving high
Is that waxstat all to do with a carby or not ??
Would it be fixed if i get a new carby or clean it out ??
Any help would e great right now, cause im goin for a camping trip with her and would like it to be fixed within a week
Cheers guys
Post Posted: Mon Dec 21, 2009 12:00 am
hey guys just an update, ive dropped the revs with a turn of the lil screw on the carby, near the acc cable lol
So now it revs at 850, just perfect thanks for all the helpful help guys
Keith
Users browsing this forum: Google [Bot] and 62 guests
