| Author |
Message |
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Sat Dec 19, 2009 9:37 pm |
hey all,
i no all about the nissan 180sx rear springs in vitara, and i have been thinking it was 300zx instead of 180 coils and managed to get some. will they fit??? as i can get them for free.
thanks guys
Mitch
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Dec 19, 2009 9:40 pm |
do you have the base width of the 300ZX coil? just see if it's the same
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Sat Dec 19, 2009 10:27 pm |
they are for free. get them and give it a go.
let us all no
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
shandy92
 Posted: Sun Dec 20, 2009 1:13 am |
yeah thanks guys, i recon i will just give it a go when u get them.
what the easiest way to change rear springs?
undo the shock, flex that corner and it should fall out?
i dont really have excess to a spring compressor but i might be able to get one if i really need it.
thanks
Mitch
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sun Dec 20, 2009 2:07 am |
I can tell you now, that even if the 300zx springs do fit, they will be a much heavier spring rate. The Z's weigh in at over 1500kg and have a fair bit or crap up back like rear steer etc, so much higher rate coils than the back of a 180.
You may find them too harsh.
shandy92
 Posted: Mon Dec 21, 2009 7:13 pm |
ok, so they may be a bit harsh but aren't all suzuki's factor with a harsh ride.
yeah i no what your trying to say and thanks.
can anybody give me the best/easiest way changing springs??
thanks
Mitch
atari4x4
 Posted: Mon Dec 21, 2009 7:32 pm |
crack wheel nuts, remove shocks, jack it up, axle stands under the end of the chassis near the front trailing arm mount, remove wheels, push down & remove springs...
I can get my MEGA long calmini springs in with out a spring compressor, they should just fall out & the new ones should just fall in.
shandy92
 Posted: Thu Dec 24, 2009 11:42 pm |
hey all,
thanks atari ill give it ago.
i still haven't received the springs from my mate yet:( but i have been tracking down some 180sx springs.
one of the wreckers has them for sale at $50 each, is that pretty good??
Fatzook did all models come with the heavier rear end? as a mate of mine used to have a 300zx and his didnt have the rear steer. im not saying that they didnt come with rear steer just that some models may be different.
thanks
Mitch
zookernator
Joined: Sun Mar 16, 2008 10:30 pm Posts: 813 Location: Tasmania
 Posted: Fri Dec 25, 2009 12:38 am |
i know where theres a pair of 180sx springs for $40.. + postage.. but that wouldnt be much. Located in Tassie. PM me if you want more details!
_________________ F&R ARB air lockers, lux diffs, 4 link coil rear,
Fatzook
 Posted: Fri Dec 25, 2009 1:33 am |
shandy92 wrote: Fatzook did all models come with the heavier rear end? as a mate of mine used to have a 300zx and his didnt have the rear steer. im not saying that they didnt come with rear steer just that some models may be different.
thanks Mitch
Hi Mitch,
ALL Z32 300zx came with HICAS rear steer. ALL of them. However I know nothing about the Z31 (pre 89), which may have had a coil rear, and most probably did not have rear steer.
This is a Z32
shandy92
 Posted: Fri Dec 25, 2009 2:50 am |
yeah ok, he still doesnt believe me, and im not going to try and prove him wrong, ohwell.
that Z32 is extreme nice and neat.
thanks for you help,
so do you guys think its a good deal for $50 each? zookernator thanks for the offer and ill keep it in mind.
thanks again
Mitch
zookernator
 Posted: Fri Dec 25, 2009 3:24 am |
i paid $20ea for mine.. only 4 weeks ago!! Oh, these arent the ones im saying are for sale either.. i'm using the coils i got for the conversion im currently doing!!
