It is currently Sat Nov 14, 2026 4:12 pm
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Sun Dec 20, 2009 10:59 pm
Hey guys, replacing the bushes in my pan hard rod over the holidays and was also hoping to get a set of castor/camber correction bushes,? Does anyone know where what how i can get some and also if i replace the front should i do the rear??
cheers
What does everyone think of this????? Im not that worried about the flex i will/might lose??????
http://stores.channeladvisor.com/Online ... 01996-1998
1997 Sierra, daily driver, 60mm coils, 2 inch body
Post Posted: Sun Dec 20, 2009 11:13 pm
The rear doesn't matter, no steering on the rear.
Pm Rusho, he's had it done to his car
Post Posted: Sun Dec 20, 2009 11:16 pm
To easy thanks man, your car is looking quite good to bet your cheering to have it back.
Post Posted: Sun Dec 20, 2009 11:51 pm
AFAIK you can't get, nor should you want/need eccentric bushes for a panhard rod but they are available for, (and handy in) lifted cars with RADIUS arms.
Post Posted: Mon Dec 21, 2009 12:26 am
Suzi sport at lawnton.....if they ain't broke in the back don't fix em'
Post Posted: Mon Dec 21, 2009 1:02 am
rear does matter with big lift, it corrects spring seat and shock pin angles on the rear end with 80mm lift and over
Post Posted: Mon Dec 21, 2009 1:20 am
cheers
That shop's friggen awesome!!! thay sell klaxton horn's!
Oh, kit look's good to. :P
Post Posted: Mon Dec 21, 2009 2:04 am
I did the front for under $200 I THINK... That was castor correction and standard bush for the rear of the front arm, like I said, I THINK. Not 100 % sure about the cost. Then there is also an alignment and fitting(apparently its a bit tricky to do)
Post Posted: Mon Dec 21, 2009 2:44 am
yeh shop goes pretty good. i go there a bit. Thanks rusho i will just have to do some research i guess. bugger. I only have 2 inch spring lift oozuk so i dont think the rear will matter.
cheers boys
Users browsing this forum: No registered users and 81 guests
