| Castor correction bushes? http://auszookers.com/forum/viewtopic.php?f=5&t=8761 |
| Author: | bigrig91 [ Sun Dec 20, 2009 10:59 pm ] |
| Post subject: | Castor correction bushes? |
Hey guys, replacing the bushes in my pan hard rod over the holidays and was also hoping to get a set of castor/camber correction bushes,? Does anyone know where what how i can get some and also if i replace the front should i do the rear?? cheers What does everyone think of this????? Im not that worried about the flex i will/might lose?????? http://stores.channeladvisor.com/Online ... 01996-1998 |
| Author: | steak_knife [ Sun Dec 20, 2009 11:13 pm ] |
| Post subject: | Re: Castor correction bushes? |
The rear doesn't matter, no steering on the rear. Pm Rusho, he's had it done to his car |
| Author: | bigrig91 [ Sun Dec 20, 2009 11:16 pm ] |
To easy thanks man, your car is looking quite good to bet your cheering to have it back. |
| Author: | want33s [ Sun Dec 20, 2009 11:51 pm ] |
AFAIK you can't get, nor should you want/need eccentric bushes for a panhard rod but they are available for, (and handy in) lifted cars with RADIUS arms. |
| Author: | Rusho [ Mon Dec 21, 2009 12:26 am ] |
Suzi sport at lawnton.....if they ain't broke in the back don't fix em' |
| Author: | oozuk [ Mon Dec 21, 2009 1:02 am ] |
steknig wrote: The rear doesn't matter, no steering on the rear.
Pm Rusho, he's had it done to his car rear does matter with big lift, it corrects spring seat and shock pin angles on the rear end with 80mm lift and over |
| Author: | steak_knife [ Mon Dec 21, 2009 1:20 am ] |
bigrig91 wrote: Hey guys, replacing the bushes in my pan hard rod over the holidays and was also hoping to get a set of castor/camber correction bushes,? Does anyone know where what how i can get some and also if i replace the front should i do the rear??
cheers What does everyone think of this????? Im not that worried about the flex i will/might lose?????? http://stores.channeladvisor.com/Online ... 01996-1998 That shop's friggen awesome!!! thay sell klaxton horn's! Oh, kit look's good to. |
| Author: | Rusho [ Mon Dec 21, 2009 2:04 am ] |
I did the front for under $200 I THINK... That was castor correction and standard bush for the rear of the front arm, like I said, I THINK. Not 100 % sure about the cost. Then there is also an alignment and fitting(apparently its a bit tricky to do) |
| Author: | bigrig91 [ Mon Dec 21, 2009 2:44 am ] |
yeh shop goes pretty good. i go there a bit. Thanks rusho i will just have to do some research i guess. bugger. I only have 2 inch spring lift oozuk so i dont think the rear will matter. cheers boys |
