It is currently Sat Nov 14, 2026 4:17 pm
Vehicle: 93 Sierra
Post Posted: Thu Apr 22, 2010 3:46 am
Need to trim the headlight buckets on my WT because my 31's are all over them under compression. The normal approach seems to be to take to them with a large hammer like BlueSuzy's below but Layto mentioned in my build thread that you can slice along the bend, slide the two sides over each other and weld them back together.
Anyone got pics of it does this way for comparison? Just want to see how it finishes off at each end of the slice when done this way. Knowing my luck I'd end up with a gap left in the guard... :roll:
Post Posted: Thu Apr 22, 2010 3:53 pm
I hammered them because it was a quick fix, Yet i still rub on the hammered part :lol:
That was a wheel off, sledge hammer job. You can get alot of room up there!
If you cut and weld, it could be made neater but for my/your size tyres, i didnt/wouldnt worry..If i was fitting 35's + then i will have to cut and weld..everything.
I may have to buy a mig 1st :lol:
Post Posted: Thu Apr 22, 2010 9:05 pm
Tim - come along on sunday and you can see how mine is done... basically the offending part is cut out and welded shut, but not smooth - instead with a 90 degree bit of plate that goes up the other way... hard to explain.
Vehicle: 93 Sierra
Post Posted: Thu Apr 22, 2010 11:02 pm
Would love to but can't :( Things on in the morning and wouldn't want to drive it offroad as it is. Still needs headlight buckets trimmed and brakelines extended before I flex it up - otherwise I'll be driving home with no brakes and cut up tyres. And 15 hour work days make working on the Zook difficult... :(
Post Posted: Thu Apr 22, 2010 11:06 pm
i always wondered what the headlight bucket on a sierra looked like... it looks nothing like a bucket!!! :oops:
Post Posted: Fri Apr 23, 2010 3:27 am
Keep bashing. Its amazing how much room you can make. I fit 32's with the diff 1" forward with no rubbing :wink:
Member of C.O.R 4x4
Users browsing this forum: No registered users and 70 guests
