It is currently Sat Nov 14, 2026 12:51 am
Post Posted: Wed Jan 13, 2010 5:04 am
i have a spare turbo sitting at home that im considering putting on the zook. what have other ppl run and their setups pics would be great. how do they handle a turbo
Post Posted: Wed Jan 13, 2010 3:35 pm
What sort of turbo are you looking at running?
Post Posted: Wed Jan 13, 2010 5:31 pm
i have a vf10 hybrid that use to be on my mazda 323 engine. quick spooling small turbo. but good for up to 16psi obviously i wont run that much in the zook.
Vehicle: I drive your mum
Post Posted: Thu Jan 14, 2010 4:55 pm
VF10 - ah the little subaru turbo of the legacy GT auto's. Make a great door stop :thefinger: . Wouldn't be too bad on a 1.3 as they are designed to boost quick on the subaru 2L auto's, but at 16psi it is a bit of its real efficency area. Im guessing you did the hybrid to get it onto your BP series motor?
Layto....
Post Posted: Thu Jan 14, 2010 6:44 pm
Layto....
BF I think?
Post Posted: Fri Jan 15, 2010 2:23 am
ScrawnC wrote:
Layto....
BF I think?
McWilly's 323 is a BP series engine.
weaves
Post Posted: Fri Jan 15, 2010 3:47 am
yea hybrid with a familia turbo. its a bpt so yea bp series. went alright at 16psi on the astina pushed out 170kw atw making it good for a 13.3 quarter. i have no idea how to setup a carby turbo though
Post Posted: Fri Jan 15, 2010 2:13 pm
Take a look at these, hope they help. I am running a K03 blowing through a 32/36 Webber.
Post Posted: Sat Jan 16, 2010 5:37 am
eEEEWWWWhhhhhh :gross:
Post Posted: Mon Jan 18, 2010 3:08 pm
Dont bother with the carby, just inject the motor. If you have set up your astina and done the conversion to the BPT then fitting basic injection setup off a vitara or simillar should not be a problem. Run a cheap old aftermarket ecu to control fueling and with low boost and maybe a rising rate regulator you should be able to keep the fuel up to it.
Layto....
Users browsing this forum: No registered users and 58 guests
