It is currently Sat Nov 14, 2026 11:18 am
Vehicle: 1987 sierra tray back buggy
Post Posted: Thu Jan 14, 2010 11:51 pm
anyone know much about the 1.5 liter engens that are in the swifts and stuff? iv seen bucket loads of turbo and supercharger kits for em and apparently thay are as easy as the baleno motors to fit to the sierras.
i dont actually wanna do it, well i do but not at the moment maybe when i blow the 1.6 iv got (it will happen trust me)
but looking at the damaged vehicle auctions i recon ya could pick one up pretty cheap and looking at the numbers it would be better than a 1.6 especially considering they are a motor buit to stick a snail on.
just after thoughts, bit of a discussion.
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Jan 15, 2010 12:57 am
i am pretty sure g15 are just destroked 1.6l engines for japanese maet (tax thing?)
In which casekits for it work on the g16....
The new M15 i imagine are not easy to put in... unless its a newish jimny?
-Santos
Post Posted: Fri Jan 15, 2010 1:04 am
helped fatzook put a M13 into his coily... not a project that i would want to be involved in again... even just from the wiring side
The M block is longer than the G block, and if the car is a post 2001 ecu it will have a rolling immobilizer code that means you cant use the stock ECU unless you have ALL of the original ancillaries (even down to the original key, ignition barrel & body control module...)
I'm sure Pete will chime in soon
Post Posted: Fri Jan 15, 2010 1:12 am
ah k
i knew it was far too good to be tru.
still interesting tho.
Post Posted: Fri Jan 15, 2010 3:19 am
But the Liana has a M18 & some of the early one's (before 2000) don't have immob at all :P :P
M16 is also commen in the early Liana's.
It's not an easy conversion by any mean's. Can be done tho. :twisted:
Post Posted: Fri Jan 15, 2010 3:47 pm
What gearbox options are there for M series engines in a north-south config? (besides an adapter plate). Obviously M13 Jimny, anything else? and like the G13-G16 are the bellhousings different on the different size M's?
Clearance Hole Technology :P
Post Posted: Fri Jan 15, 2010 6:58 pm
M series are all the same. Jimny is the only N-S box as far AFAIK.
Users browsing this forum: Google [Bot] and 63 guests
