It is currently Sat Nov 14, 2026 10:02 am
Post Posted: Tue Jan 12, 2010 1:03 am
I have a 1.6 8valve carby motor and 1.3 head In my Sierra and when I first put it in it was backfiring alot and carrying on. I swapped the 1.3 carb for a 1.6 one and done the timing which fixed the backfiring etc
All of a sudden it has become smoky at high rpm and using oil. it seams to be fumy and a bit sluggish but it has similar characteristics to what my original 1.3 had
any ideas what it could be?
Post Posted: Tue Jan 12, 2010 1:38 am
fumey as in overfueling, or as in white smoke/ oil?
Post Posted: Tue Jan 12, 2010 2:08 am
The fumes have something to do with the oil consumption but it doesn't smell like the usual oil burning smell it's an odd fume not fuel but not oil if that makes any sense
Post Posted: Fri Jan 15, 2010 12:14 am
I was told something about Sierra fuel pumps crapping themselves and pumping fuel into the oil what's the chance if this being the problem
Post Posted: Fri Jan 15, 2010 12:19 am
i bet its too rich and washing the oil off and burning it
Post Posted: Fri Jan 15, 2010 12:50 am
Washing the oil off? What does this mean?
It's using a crap load if oil was almost on the low mark on thedipstick after the run to glass house mountains on Sunday.
Post Posted: Fri Jan 15, 2010 2:25 am
When an engine is built the cylinders are bored and HONED.
The honing process leaves (approx) 60 degree cross hatching in the bores.
These fine scratches are put there to trap a small(tiny in fact) amount of oil to lubricate the piston rings as they slide up and down the bore.
If the fuel/air mixture is too rich then the excess petrol will wash the oil out of the hone scratches resulting in excessive wear to both piston rings and cylinder bores. It also ruins the engine oil which makes all other engine components wear out faster.
Jas.
Post Posted: Fri Jan 15, 2010 2:52 pm
Ah ok I'll try sort that out then asap
Post Posted: Sat Jan 16, 2010 12:44 am
Is there some way I can test how rich it is running?
Could it also be valve stem seals? I started it up for the first time since Sunday an it coughed and farted and blew a heap of smoke then cleared up which is exactly what my 1.3 was doing.
I'm convinced they both have the same problem
Post Posted: Sat Jan 16, 2010 1:43 am
That is a symptom of valve stem seal's, if you let it idle for around 2 min's then give it a rev (not a valve bounce) it will blow smoke to, if the stem seal's are gone.
Thay can be done on car to :P :P :P
Post Posted: Sat Jan 16, 2010 2:02 am
Yeah well I have I have a head here with new valve stem seals that could be my problem!
Users browsing this forum: No registered users and 76 guests
