It is currently Mon Oct 12, 2026 9:14 am
Vehicle: 95 Sierra Soft top
Post Posted: Sat Jan 16, 2010 6:48 pm
Hey guys
just went to take my zook out and found a small puddel of oil under my right hand rear wheel, smells like diff oil and its got abit of grey in it so im thinking it is :(
Its leaking on both sides from the wheels, well some oil is sitting in the rim on each side
I went up and down the drive way and everything runs fine, so again im thinking diff seals or something
What do you guys think and how should i go about fixing the bloody thing
Cheers guys
Vehicle: Nissan
Post Posted: Sat Jan 16, 2010 6:56 pm
replace the seals change the diff oil and make up some breathers :wink:
and wile you got the axels out do the rear wheel bearings :wink:
Pearce-toff Racing
Post Posted: Sat Jan 16, 2010 6:59 pm
x2 If you got the spare coin do the brakes if needed also
Post Posted: Sat Jan 16, 2010 7:00 pm
This sounds like a big job ?? Axels out :? what kinda tools will i be needing to do all this ??
Vehicle: Nissan
Post Posted: Sat Jan 16, 2010 7:05 pm
pice of piss 4 nuts on the backing plate and put the drum back on backwords and yank it till the axels pop out or if ya got an axel puller use that :P :D but thats after you remove hand brake cable and disconect brake line :wink:
Pearce-toff Racing
Post Posted: Sat Jan 16, 2010 7:09 pm
Sorry mate would you be able to type that all down step by step, from what you just said it doesnt seem that hard
and where would the seals be located ??
EDIT:
what parts will i be needing ?? does any one have part numbers ??
Vehicle: Nissan
Post Posted: Sat Jan 16, 2010 7:24 pm
EDIT:
step 1: jack rear diff up put stands under diff
step 2: remove wheels and drums with rattel gun
step 3: clamp flexie brake line and remove brake line to w/cylinders
step 4: remove hand brake cabel, theres a littel pin that holds it there
step 5: undo 4 bolts on backing plate
step 6: put drum on backwords and yank it had till the axels come out
step 7: get seal puller or screw driver and pop seals out
step 8: put new seal in with a small hammer you can also yous the old seal to tap on to push the new seal it with.
the seals are located in the end of the housing make shour you dont score the race which the seal sits in :wink:
hope this helps any extra info please correct me
Pearce-toff Racing
Vehicle: Nissan
Post Posted: Sat Jan 16, 2010 7:27 pm
you will need rear axel seals diff oil and some hose if your doing diff breathers
Pearce-toff Racing
Vehicle: Nissan
Post Posted: Sat Jan 16, 2010 7:31 pm
if you dont know how to do it get someone to show you or take it to a mechanical shop coz its not that hard to screw it up :wink:
Pearce-toff Racing
Vehicle: Clown Car..
Post Posted: Sat Jan 16, 2010 8:06 pm
a few pics in here to give you an idea whats involved...
http://www.auszookers.com/index.php?nam ... pic&t=1943
Post Posted: Sat Jan 16, 2010 8:25 pm
Thanks alex that helps out alot, but i think ill call my mechanic around to give me a hand, i can do it but in the past things like this i tend to brake and stuff up lol (Bloody Swift GTI !!!)
And thanks foolsp33d the pics did help, ill start it off for my mechanic and pull everything off might be cheaper that way lol
thanks again guys :wink:
Post Posted: Sat Jan 16, 2010 11:36 pm
Is this what it looks like ??
http://www.suzistore.com.au/shopexd.asp?id=50
and then put this in front of it yeah
http://www.suzistore.com.au/shopexd.asp?id=803
And how would yous go about making diff breathers and where would you put them out of the way in the back of a soft top ??
Post Posted: Sat Jan 16, 2010 11:41 pm
youll need new brake shoes cause the oil stuffs em
and if you are replacing shoes you should do cylinders to cause they will just leak when you push em back in
and if you are doing cylinders they will need a bleed so you may as well flush the brakes cause it probably hasnt been done in years
see how the little things become a big job :)
Post Posted: Sun Jan 17, 2010 1:59 am
LOL yeah i have noticed that :lol:
But the parts that i linked up there are right ??
Post Posted: Sun Jan 17, 2010 2:33 pm
But from my very limited experience, Suzuki's are easier to do & don't *usually cost as much. :P
You didn't buy a Suzuki, you got a hobby!!!!! :P 8) :wink:
EDIT: * Please note that price's may vary from store to store.
Vehicle: 07 vvt jimny
Post Posted: Thu Dec 02, 2010 11:16 pm
all of this can be dont in no time at all :D:D:D i love big job when u have all the equipment to put on.
sorry CHOP :P
Jimny's Are taking Over
Users browsing this forum: Google [Bot] and 324 guests
