It is currently Wed Jul 01, 2026 12:05 am
Post Posted: Tue Jan 19, 2010 1:09 am
im just asking if anyone knows if the 2002 steering box will fit into the sierra
Post Posted: Tue Jan 19, 2010 1:14 am
No it won't...give it to me :wink: I think I remember Fatzook telling me a jimny one does, not sure about the year model..could be wrong.
Post Posted: Tue Jan 19, 2010 1:31 am
Rusho81 wrote:
No it won't...give it to me :wink: I think I remember Fatzook telling me a jimny one doesnot sure about the year model..could be wrong.
X2, have heard the same thing, not seen it tho.
Do you have pic's?? Or is it still in a car....
pretty sure alll jimnys are the same in which case yes it will fit
Post Posted: Tue Jan 19, 2010 1:47 am
X 3.528 ... Jimny powersteer box bolts into Sierra.
Post Posted: Tue Jan 19, 2010 3:57 am
yes they fit, .........give ya $50 for the p\s kit
Post Posted: Tue Jan 19, 2010 5:22 am
I hoped 2 find out if tha power steering would fit my 91sierra as well. coz as sum of you guys would know a welded front diff gets a bit hard 2 turn after a while!!!
Post Posted: Tue Jan 19, 2010 12:52 pm
yah bolts on mate but isn't cheap.
Post Posted: Tue Jan 19, 2010 12:58 pm
Not cheap but I think it bolts in without an adapter kit
Post Posted: Wed Jan 20, 2010 12:34 am
just picked it up bought the pump and box for $350 haha right place at the right time i got it from All 4wd Off-Road Archerfield
Glenister Street
Archerfield, QLD, 4108
Post Posted: Wed Jan 20, 2010 6:42 am
I have a 2007 jimny power steer box pump and reservoir. all I needed was a vee to Multi Vee front bot pulley (got it from Low Range) and all bolted up sweet slight mod to front panel to clearance the box but only other issue was the sierra pitman arm had a smaller spline so had to drill 2 holes in Jimny arm to get steering dampner to fit. Will get sierra arm resplined when I can get someone to share the cost with (EG to get one re splined is $300 to get two done is $400 -$450)
I also did away with all the metal lines and replaced with flexible pressure line thanks to a mate.
Only other thing I installed was a power steer oil cooler to keep oil cool during the technical low tight turning tracks.
The missus thinks its great best mod done.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Wed Jan 20, 2010 2:53 pm
zuki wrote:
.....had to drill 2 holes in Jimny arm to get steering dampner to fit.
That was a waste of time as Sierra/Jimny/Vitara powersteer boxes don't need a damper. Mine is better now it's power without a damper than it was before with it.
Getting the Sierra arm resplined will be a waste of money too.
Users browsing this forum: Google [Bot] and 173 guests
