http://auszookers.com/forum/
drive shaft spacer for a coily
http://auszookers.com/forum/viewtopic.php?f=5&t=9397
Author:  Ridge [ Sun Jan 24, 2010 10:35 pm ]
Post subject:  drive shaft spacer for a coily
since i have liffted my transfer case, the teeth are showing on the rear drive shaft. would i be able to fit a spacer for a wt? ill get some pictures up soon
Author:  want33s [ Sun Jan 24, 2010 10:36 pm ]
Post subject:  Re: drive shaft spacer for a coily
One of the few parts that will fit a coily are leafy shafts so a WT spacer will bolt straight in.
Author:  Ridge [ Sun Jan 24, 2010 10:44 pm ]
thanks, ill try and get one before next weekend
Author:  Junior_91 [ Mon Jan 25, 2010 12:44 am ]
I have a spacer mate it's 3/4" brand new.
Author:  Reubs [ Mon Jan 25, 2010 5:58 pm ]
Hi Ridge. How much lift do you have?
Have you ever greased the shaft? That should push the rubber boot back over the exposed spline. If not, you might need one. I haven't bothered with one. I have 40mm spring lift + 50mm t/case lift.
Reubs.
Author:  Ridge [ Mon Jan 25, 2010 10:30 pm ]
i have a 40mm suspension lift and a 40mm transfer lift. i have greased the shaft but the boot wont cover the spline.
junior_91 you have a pm
