| brake problem, thinking disk conversion, Grand vitara http://auszookers.com/forum/viewtopic.php?f=5&t=9421 |
| Author: | experament-u2 [ Mon Jan 25, 2010 11:23 pm ] |
| Post subject: | brake problem, thinking disk conversion, Grand vitara |
im having major rear brake hassle with my grand vitara (1.6) most of the components are rusted pretty bad from a previous owners (ok and maby a bit from me) lack of cleaning, parts keep breaking and to replace them through genuine will cost a arm and a leg. i cant find any wrecked GV so no luck scavenging bits. i was thinking maby doing a rear disk conversion muddy zook do a kit here http://www.muddyzook.co.uk/store/index. ... roductId=6 its either that or try and fit a later model vitara hub plate and internals (brake shoes and that) while using the grand vitaras drum and axel. dose anyone know if this would work. as finding parts for the erlyer vitaras is alot easier. thanks |
| Author: | gravity_powered [ Tue Jan 26, 2010 1:04 am ] |
| Post subject: | Re: brake problem, thinking disk conversion, Grand vitara |
Exclusive Jap http://www.exjap.com.au/ in Adelaide should be able to sort you out with all the replacement drum bits you need. The GV didn't come with disks on the rear that I know of, so a conversion is going to be a fair bit of stuffing around. |
| Author: | joeblow [ Tue Jan 26, 2010 1:08 am ] |
that kit will not be legal here in aus. |
| Author: | experament-u2 [ Tue Jan 26, 2010 2:04 am ] |
gravity_powered wrote: Exclusive Jap http://www.exjap.com.au/ in Adelaide should be able to sort you out with all the replacement drum bits you need. The GV didn't come with disks on the rear that I know of, so a conversion is going to be a fair bit of stuffing around. thanks mate iv sent them a email lets hope they can find some joeblow wrote: that kit will not be legal here in aus.
if i was going to go down this route i would need to get it engineered i talked to a mate down at the MVR, thanks tho |
