It is currently Thu Oct 08, 2026 3:29 pm
Post Posted: Sun Jan 24, 2010 10:35 pm
since i have liffted my transfer case, the teeth are showing on the rear drive shaft. would i be able to fit a spacer for a wt? ill get some pictures up soon
Post Posted: Sun Jan 24, 2010 10:36 pm
One of the few parts that will fit a coily are leafy shafts so a WT spacer will bolt straight in.
Post Posted: Sun Jan 24, 2010 10:44 pm
thanks, ill try and get one before next weekend
Post Posted: Mon Jan 25, 2010 12:44 am
I have a spacer mate it's 3/4" brand new.
TWIN LOCK IT & JUST DRIVE!
Vehicle: SJ80, SE416
Post Posted: Mon Jan 25, 2010 5:58 pm
Hi Ridge. How much lift do you have?
Have you ever greased the shaft? That should push the rubber boot back over the exposed spline. If not, you might need one. I haven't bothered with one. I have 40mm spring lift + 50mm t/case lift.
Reubs.
Post Posted: Mon Jan 25, 2010 10:30 pm
i have a 40mm suspension lift and a 40mm transfer lift. i have greased the shaft but the boot wont cover the spline.
junior_91 you have a pm
Users browsing this forum: Google [Bot] and 178 guests
