It is currently Sat Nov 14, 2026 11:59 pm
Post Posted: Thu May 03, 2007 1:23 am
just a quick question on aircon for a 92 swb vit carbie. Any one put aircon in there car and how hard is it (like do it your self or need pro job) ???
Post Posted: Thu May 03, 2007 2:59 am
When I had it fitted to mine I just took it to a shop down the road. They charged about $200 to fit and gas it. It was a factory system.
Post Posted: Thu May 03, 2007 8:00 pm
did u buy it from the wreakers ????
Post Posted: Thu May 03, 2007 9:16 pm
i have a whole system from a 2.0 V6 which should be not too hard to fit if your interested.
Post Posted: Thu May 03, 2007 9:25 pm
how much ??
Post Posted: Fri May 04, 2007 12:41 pm
looking for about 250
Post Posted: Fri May 04, 2007 12:54 pm
I would think the v6 one would have very little in common with a 92 carby system
Post Posted: Fri May 04, 2007 1:00 pm
surely the only thing in common it needs is a bracket to fit the compressor to the engine. the rest of the system is there including airbox etc
Post Posted: Fri May 04, 2007 1:45 pm
different dash layout on the V6?
the V6 one would take cues from the ECU on what to do, carby one doesnt have that
pipe layout in engine bay etc
Post Posted: Fri May 04, 2007 6:03 pm
meh, even then its not impossible, just a bit more work.
Post Posted: Fri May 04, 2007 6:55 pm
yeah a bit more work = buying new parts and paying more labour for system that will be a patched up mess compared to just getting the right system to suit the car
I could get a corolla system for $100 I reckon, be the same effort to fit
Post Posted: Thu May 10, 2007 1:01 am
corolla hey, sounds interesting :) should i hit the wreakers up you recon ?
Post Posted: Tue May 15, 2007 8:04 pm
what year make and model would you recommond
Post Posted: Tue May 15, 2007 8:28 pm
i dont think he meant that corollas have a "bolt on" aircon for a vit....
he was just using the corollas aircon as an example, basically, the v6 vitara is a different engine therefore aircon system, so fitting it to the 1.6 will be the same amount of work as fitting a system thats 150 dollars (approx) cheaper for the same effect.
curiosity killed the colt.
Users browsing this forum: Google [Bot] and 64 guests
