It is currently Sun Nov 15, 2026 6:04 am
Post Posted: Thu May 03, 2007 3:12 pm
I have found a Mod Certifyer who will happily mod plate rear disk brake swap as long as i use a fabricated kit from somewhere like suzisport. My question is i have heard that you can use pintara calipers to retain the rear cable handbrake. Does any one know if this means that the pintara ones are the same bolt pattern eg bolt straight up? or if they need modification to the kit ie drilling welding. making it harder to get it plated.
Post Posted: Thu May 03, 2007 3:19 pm
they are different but I am prety sure they bracket you need to make up can be made from flat steel so no bending or welding required
pulsar rear are similar but need a spacer to line the caliper up
Post Posted: Fri May 04, 2007 2:14 am
mine doesn't go fast enough to need rear discs!!
Vehicle: LJ20 LJ50
Post Posted: Sat May 05, 2007 12:06 am
No sierra does.
Camels have nice toes
Users browsing this forum: No registered users and 45 guests
