It is currently Sat Nov 14, 2026 10:07 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Fri May 04, 2007 7:03 pm
where do u guys get ur Rockhopper gears from and how much did u pay for them?
thanks :wink:
Post Posted: Fri May 04, 2007 7:06 pm
suzisport a million years ago for $1000 :)
Calmini :wink:
Post Posted: Fri May 04, 2007 7:07 pm
is that s2's?
Post Posted: Fri May 04, 2007 7:27 pm
yeah bit between the other ones
lot stronger though
Post Posted: Fri May 04, 2007 8:04 pm
rocklobster
http://www.auszookers.com/index.php?nam ... c&start=75
$220 + cases
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Fri May 04, 2007 8:17 pm
yea got both cases, prob could do this!
probably get my brother to do it!
Post Posted: Fri May 04, 2007 8:37 pm
yeh mines been done for a bit now with no dramas
makes sense if u got both
Vehicle: MY2019 Jimny
Post Posted: Fri May 04, 2007 10:42 pm
Is there a write up anywhere on what to do?
Post Posted: Fri May 04, 2007 10:44 pm
www.auszookers.com/ind...c&start=75
Post Posted: Fri May 04, 2007 10:46 pm
Nope - Dead link
Post Posted: Fri May 04, 2007 10:48 pm
go to my introdce page, page 5 i think
Post Posted: Fri May 04, 2007 10:49 pm
k thanks Oscar
Post Posted: Fri May 04, 2007 11:14 pm
page 6 sorry
no worries, i can organise the gear work if needed
Post Posted: Sat May 05, 2007 12:04 pm
ok im new to the 4WD scene. what do i need to get.. 1x complete 1.3 transfer plus 1x 1ltr transfer???? than swap and machine gears from 1ltr to put in my 1.3 housing??? thats what i can make out from reading page 6 to 9.......by the way i have a 92 seirra with 1.3:)
michael
Post Posted: Sat May 05, 2007 12:12 pm
yeh thats right.u dont swap all gears just ones stated.also keerp or replace the bearings of the 1.3.
the 1l case must be the one with switch i think without the drum onit.
Post Posted: Sat May 05, 2007 5:12 pm
What year 1.0L T cases?
Also, does it make reverse extremely low also? If so, itt worries me a tad, as that is how I get out of bogs most of the time - rocking back and fowards like a crazy lady...
Post Posted: Sat May 05, 2007 6:13 pm
its almost the same as series one gears
Post Posted: Sat May 05, 2007 11:37 pm
reverse is fine, yep practicle series 1
Post Posted: Sun May 06, 2007 12:10 am
Can the gear just be bought rather than buying a 1L Tcase?
Vehicle: LJ20 LJ50
Post Posted: Sun May 06, 2007 12:43 pm
It only changes low range high range remains the same
And the reduction in standard 1.3 is 2.2:1 in low. This gives you 2.5:1 in low range instead
Camels have nice toes
Post Posted: Sun May 06, 2007 1:24 pm
[/quote]
And the reduction in standard 1.3 is 2.2:1 in low. This gives you 2.5:1 in low range instead[/quote]
is that change from 2.2 to 2.5 worth the messing around... does it make mch of a defference??
and is any one willing to make up one to sell as a change over/ exchange. if so how much... not that im lazy just dont want to mess it up and cost more :D :D
Post Posted: Sun May 06, 2007 1:45 pm
and is any one willing to make up one to sell as a change over/ exchange?
Make that 2...
Post Posted: Sun May 06, 2007 1:47 pm
yes u can buy the gear but its costly, to me it was worth the mess around.
isn't series 1 good enough for u? i have 32in tyres and think its fine. Its 90% reduction in low?
if i had the time i would but got to many things going on thsi year.
i think its any after like 86 or 89. ask royce or steve they should know
if u dont have both cases just buy some gears.
Post Posted: Sun May 06, 2007 2:21 pm
I think everyone is getting confused here
based on 1.3 standard gearing
a 1 litre transfer drops overall gearing (high and low) by about 10%, useful to get your gearing back after fitting bigger tires but no bonus off road
a series one transfer give 1 litre high range gearing and a 4.16 low ratio, which is about 90% reduction in low range and very useful in all but sand, top speed is about 35kmhr in low 5th gear
then there is the calmini set, they are 5.12 low range, and the same as above in high (I think), they are also known to be very strong and well built gears, but sometimes hard to get, they are good for 31-32" sierras that are also street driven
then the series 3, they are like 6.5 or something in low range and 20%reduction in high, might be pushing it on road with anything smaller than 31's and IMHO they are a bit too low for smaller than 33's but thats just talking out my ass cause I never had them so others would be better to comment, there have also been issues of the gears breaking for no reason.
the ones oscar have is basically a few gears from a 1.3 and a few from the late 1 litre transfer (look for the 1 litre case with a 4wd switch, thats the one you need) its the same gearing as series one (infact early series ones were just this till they started making new gearsets) and if you can get the machine work done for a decent price and good quality they will go the distance, mine did over 100 000km and are still going strong somewhere I imagine
given most gears cost $1000 vs the cost of finding a late 1 litre transfer and getting the work done you may or may not come out in front, it really hinges on how cheap you can find a transfer
Post Posted: Sun May 06, 2007 3:23 pm
now thats what we needed.
i can get the gears done for $220 there abouts.
If u dont want some experience in this stuff ask ya local mechanic, he maybe able to help with the disasembleing and assembling.
my total cost was 1l case-already had.$150
gears. $220
bearings and seals are optional. $130 i think
Post Posted: Thu May 17, 2007 12:43 am
hey do u know wat the engineer welded the gears with?
Post Posted: Thu May 17, 2007 1:10 am
looks like normal mig to me!!
so no-one willing to make up a few transfers??
Post Posted: Thu May 17, 2007 1:13 am
nah i don't think it is!
cause there hardened gears. maybe tig of arc?
Post Posted: Thu May 17, 2007 1:17 am
arr yes it does look tig by that last pic
Post Posted: Thu May 17, 2007 2:09 am
i'd say tig which is the best for that sort of thing.. naah sorry but i got no time to work for other atm. got to much to do on my own.
Users browsing this forum: Google [Bot] and 89 guests
