| Coily Steering shaft uni and dampner http://auszookers.com/forum/viewtopic.php?f=5&t=9604 |
| Author: | bigrig91 [ Wed Feb 03, 2010 1:05 am ] |
| Post subject: | Coily Steering shaft uni and dampner |
Anyone know where i can source one. Told i can get it rebuilt but for alot of $$. I have looked on suzistore and no dice? Also can anyone recommend a steering dampner other than the one from suzi sport???? |
| Author: | Saam [ Wed Feb 03, 2010 1:21 am ] |
| Post subject: | Re: Coily Steering shaft uni and dampner |
steering dampers are gay cut the bracket off of a widetrack chassis and take the mount from a wide track pitman arm then get a damper suited to them. Steering shaft uni, go to wreckers and find a nice looking one that measures the same, mine came from an sr20 GTIR pulsar front cut. Sierraless Saam. |
also want33's has a chassis you can get bits off, i was going to do it before i got rid of mine |
| Author: | bigrig91 [ Wed Feb 03, 2010 1:49 am ] |
Awesome job again Sam. You really should have a zook! Cheers mate |
| Author: | PJ.zook [ Wed Feb 03, 2010 12:10 pm ] |
Make youre own dampner. I used a 40 series dampner from Ironman, made up a bracket to bolt it to pitman arm, and used some box section at other end welded to the crossmember. |
| Author: | tuffcoily [ Sat Feb 06, 2010 1:32 am ] |
One stop suzi shop at nerang has heaps of them if you have a body lift get one out of a 92 wide track it is a little bit longer so it takes the strain off the rag joint. |
