| Back Breaker SUSPENSION http://auszookers.com/forum/viewtopic.php?f=5&t=9781 |
| Author: | carlgarson [ Wed Feb 10, 2010 6:23 pm ] |
| Post subject: | Back Breaker SUSPENSION |
I have bought a 1990 Sierra w/t 1.6ltr G16 carby engine 31''mt on 15x8sunnies 2''body lift 2''suspension lift extended shackles driving at 30ks on fire trail few bumps and holes suspension is very hard and stiff rattles the sxxx out of you how can i make it a more comfortable ride even go a bit quicker,have taken air pressure down to 20psi have a stock 1987Sierra rides like a dream compaired to Sierra above |
| Author: | want33s [ Wed Feb 10, 2010 6:46 pm ] |
| Post subject: | Re: Back Breaker SUSPENSION |
Take the extended shackles out...Replace with standard. Will give you back some lost shackle angle and ride a lot smoother. After that you might want to drop a leaf or two out of each spring. |
| Author: | Damo [ Wed Feb 10, 2010 6:48 pm ] |
I bet they are Kings springs |
| Author: | Choppy [ Wed Feb 10, 2010 6:55 pm ] |
my suspension was the same, i didnt have extended shackles but felt like i needed a to see a chiro afta drivin. definately drop a leaf, ive taken a leaf out of each pack and gonn a take another out of the rears. how many leafs in each pack?? also agree with want 33's changing shackles will make considerable difference. |
| Author: | peeeete [ Wed Feb 10, 2010 7:21 pm ] |
Damo wrote: I bet they are Kings springs
x2 I get thrown about when I go over the new bitumen where there used to be potholes! Let alone anything over 10mm high... |
| Author: | ZookiMonsta [ Wed Feb 10, 2010 7:47 pm ] |
Mine used to hit the bump stops if I ran over anything higher than a thong. the corrigations off road. |
| Author: | steak_knife [ Wed Feb 10, 2010 11:23 pm ] |
peeeete wrote: Damo wrote: I bet they are Kings springs x2 I get thrown about when I go over the new bitumen where there used to be potholes! Let alone anything over 10mm high... I used to race on em, no problem's, the only time any one bent one was if thay hit some thing. To the original question, what want33s said & 20 psi should be your street pressure, off road you should drop down to around 15 psi. |
| Author: | jakeyr [ Thu Feb 11, 2010 1:05 am ] |
is it hard to take out a leaf spring |
| Author: | 2stroker [ Thu Feb 11, 2010 1:16 am ] |
jakeyr wrote: is it hard to take out a leaf spring
removing a leaf is pretty easy with only basic tools required Hey steknig it's all cool, if people keep baging the kings we should be able to get them cheaper. |
| Author: | 2stroker [ Thu Feb 11, 2010 1:28 am ] |
peeeete wrote: Damo wrote: I bet they are Kings springs x2 I get thrown about when I go over the new bitumen where there used to be potholes! Let alone anything over 10mm high... Pete, out of interest what combination are you running, what part number kings (there are 3 variations available), what shocks, what size wheels and tyres. |
| Author: | steak_knife [ Thu Feb 11, 2010 1:32 am ] |
2stroker wrote: jakeyr wrote: is it hard to take out a leaf spring removing a leaf is pretty easy with only basic tools required Hey steknig it's all cool, if people keep baging the kings we should be able to get them cheaper. |
