It is currently Tue Sep 29, 2026 1:41 pm
Post Posted: Fri Feb 12, 2010 4:23 am
I've just finished putting my spare case back together with my 4.16 gears in it and I've hit a bit of a hurdle...
I decided to give it a trial run in the back yard before swapping the cases over, everything spins fine, it shifts between 4-Lo and 4-Hi no dramas, but I can't get it to shift into 2-Hi..
Any ideas?? I really want the gears in for the weekend!
I want my old sig back :(
Post Posted: Fri Feb 12, 2010 4:27 am
Shifter shafts not lined up properly, put it in 4H pull the shifter out and line up the grooves in the shafts
Post Posted: Fri Feb 12, 2010 4:32 am
I assume that the two cut-outs in the shafts need to be together, is that right?
I may have to leave it til morning now... But I'll give it a try....
Any other suggestions just in case it isn't that?
Post Posted: Fri Feb 12, 2010 4:50 am
Nahh mate Just Cruizin hit it spot on. You have it out of sink. pull the shifter out use a screw drive to make the gates both lined up at the engine end of the hole. Put the shifter back in and away you go.
Post Posted: Fri Feb 12, 2010 1:18 pm
Won't the middle detent ball stop that from happening.
More like the shifter was put in in the wrong gate to start with??!!!
Post Posted: Fri Feb 12, 2010 3:11 pm
Thanks for the help guys :D
Users browsing this forum: No registered users and 125 guests
