| Author |
Message |
mcwilly
Joined: Sun Sep 21, 2008 11:30 pm Posts: 867 Location: nsw, newcastle
 Posted: Mon Feb 08, 2010 3:42 am |
Does it effect how the drop shackles work if they are faced inwards or outwards? Because slot of people mount them facing out but they are meant to face inwards??
_________________ 1996 sierra + 2" body lift + SPOA conversion + ome
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Mon Feb 08, 2010 3:45 am |
Fronts or rears?
if rear wouldnt they hit on the tank? just mounth them outwards if you have to, it will only reduce your approach departure angle
_________________ I'm Weaver & i like beer, boobs, cars and stickers
mcwilly
 Posted: Mon Feb 08, 2010 3:51 am |
Inwards hits fuel filler but I don't know if they will open properly facing out it's for the rear fronts r done
v.w.dave
Joined: Sun Sep 27, 2009 11:30 pm Posts: 1437 Location: The Hills Sydney
 Posted: Mon Feb 08, 2010 3:52 am |
they are ment to be mounted inwards but when there is no room it is ok to mount then the other way.
_________________ Snap-On Dealer let me know if you need anything.
mcwilly
 Posted: Mon Feb 08, 2010 4:11 am |
So they still should fully open
v.w.dave
 Posted: Mon Feb 08, 2010 4:24 am |
yes. They are designed to go in for angles as said above. the other reason why you want to keep them in is they are harder for the po po to see.
weaves
 Posted: Mon Feb 08, 2010 4:25 am |
I cannot think of a reason they wouldn't.
they fully swing on the pin. they still open the same distance, they just fold the other direction.
plus if they dont fit the other way you really have no choice.
birko
Joined: Sun Jun 07, 2009 11:30 pm Posts: 573 Location: Perth WA
 Posted: Tue Feb 09, 2010 1:17 am |
I have just fitted front and rear climax shackles. They both fit facing inwards, the rear drivers side just touches the fuel hose cover and has very slighty bent it in, no big deal. This is with a 2' bodylift also.
mcwilly
 Posted: Tue Feb 09, 2010 4:53 am |
That's the metal cover or the hose itself?
BlueSuzy
 Posted: Tue Feb 09, 2010 5:08 am |
If your running those tyres^^
Why do you have that cover still in? Mine is long gone...Tyre used to rub on it hard..Then i had to strap back the fuel hose..!
mcwilly
 Posted: Tue Feb 09, 2010 5:39 am |
I'm running 35 silverstones and it doesn't touch it. It's no where near it. I might try my front climax on the rear tomorrow
mcwilly
 Posted: Tue Feb 09, 2010 5:57 am |
Do you run a tow bar birko?
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Tue Feb 09, 2010 11:04 am |
haha it will work either direction, i painted mine black and had them facing out as i couldn't be bothered to mess around with fuel hoeses and such. also i have no idea on how the 35's don't touch everywhere....
mcwilly
 Posted: Tue Feb 09, 2010 11:33 am |
Bump stopped and big hammer for the front guards the rears just clear. Front just touches technically they are 34.7 but that's pretty much 35
zookernator
Joined: Sun Mar 16, 2008 10:30 pm Posts: 813 Location: Tasmania
 Posted: Tue Feb 09, 2010 4:12 pm |
I was running the climax drop shackles facing backwards (on the rear) of my zook for a while.. and they never opened up fully.. when i turned them around, they did. Been like that ever since!!
_________________ F&R ARB air lockers, lux diffs, 4 link coil rear,
mcwilly
 Posted: Thu Feb 11, 2010 12:41 pm |
Any pics of the fuel filler and climax birko
birko
 Posted: Fri Feb 12, 2010 3:21 am |
Hey,
Sorry mate been a bit busy lately. Ill try get some pics tommorrow. Yep i run a towbar. The metal im talking about is the flismy hose cover bit. Just try them both ways and see which is better, its only a 10 minute job.
mcwilly
 Posted: Fri Feb 12, 2010 6:04 am |
Thanks mate. I only have one pair so far and they are on the front. I might try it over the weekend.
TonkaTuff
Joined: Sun Jan 31, 2010 10:30 pm Posts: 10 Location: Cairns
 Posted: Fri Feb 12, 2010 12:35 pm |
mcwilly wrote: Thanks mate. I only have one pair so far and they are on the front. I might try it over the weekend.
Any particular reason front?
If I was runnin only 1 pair, I'd run rears simply because you do loose a bit of steering because of the flex in the front set. (I run F&R)
mcwilly
 Posted: Fri Feb 12, 2010 6:08 pm |
Because the rear sat higher then the front to start with so it evens the height up now otherwise it would of been heaps higher in the rear. Have u got pics of the right rear with fuel filler
TonkaTuff
 Posted: Fri Feb 12, 2010 9:34 pm |
mcwilly wrote: Because the rear sat higher then the front to start with so it evens the height up now otherwise it would of been heaps higher in the rear. Have u got pics of the right rear with fuel filler
Will take some and put em up sunday (My rears do face out though!)
mcwilly
 Posted: Sat Feb 13, 2010 3:56 am |
Do they open properly that way?
