[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Schnerb
Joined: Thu Jan 28, 2010 10:30 pm Posts: 68 Location: melbourne
 Posted: Tue Feb 23, 2010 1:20 am |
hey guys,
one casualty of the weekends wheeling was the ac seemed to stop working. it was blowing fine and cold on the way down there, and then after i went through the first large rut, it stopped. I have cleaned out the engine bay to see if that would help, but hasnt seemed to do anything... any ideas? i wouldnt have thought it was a gas issue, as it was working fine in the morning. not sure if the compressor is working, havent had a good look, but any guidance would be appreciated, as i dont really know what to look for
thanks guys
_________________ 98 Jimny - 2 inch lift. 235 maxis bighorns. spotti
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Tue Feb 23, 2010 2:50 am |
did ya flick anything up and puncture the condensor? well the compressor the main thing you can check yourself is with the engine running ensure that the clutch is kicking in on the front of the compressor
gman
Joined: Tue Dec 01, 2009 10:30 pm Posts: 172 Location: Longford, Tasmania
 Posted: Tue Feb 23, 2010 3:12 am |
Firstly I would check the A/C fuse under the bonnet.when sitting in the car with the engine running you should be able to hear the compressor clutch click loudly as you turn on the A/C than hear the cooling fan start up if no click try the wire going to the compressor, is it connected? the 4wd fuse will affect the A/C also you'll find the green light won't be lit too. try that finnally with the engine off try spinning the compressor by hand (the centre part of the pully) it should be free to spin. if the gas has escaped the A/C module won't allow the compressor to start. check the fuses first and the comp clutch wire. most common problems in my Jimny history
Good Luck.
Gav
gman
 Posted: Thu Feb 25, 2010 2:06 am |
Schnerb
 Posted: Fri Feb 26, 2010 11:09 pm |
nothing yet. will be working on the cars on sunday. let you know from then
Zooksta
Joined: Thu Oct 08, 2009 10:30 pm Posts: 68 Location: FNQ, Cairns
 Posted: Sat Feb 27, 2010 2:32 pm |
My air con shitted itself about a month ago, there a solonoid thingy lol on the exhuast side that fucks up all the time from the heat (apparently a common thing)
_________________ Doug
steak_knife
 Posted: Sat Feb 27, 2010 2:42 pm |
Zooksta wrote: My air con shitted itself about a month ago, there a solonoid thingy lol on the exhuast side that fucks up all the time from the heat (apparently a common thing)
Clutch maybe???
[ 7 posts ] |
Users browsing this forum: No registered users and 79 guests
