Hi,I recently purchased an SJ80 coily with a G13ba & have replaced water pump,thermostat,engine pipe,"O" ring,top & bottom hoses and intake manifold gasket & still have a water leak.
It appears to be coming from the bellhousing. Could it be a heater hose (although I can't see it) or a welch plug at the rear of the block.
If I remove the gearbox is the welch plug easy to get at?
Any help appreciated.Cheers.
Users browsing this forum: Google [Bot] and 125 guests
