[ 8 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
sbyard
Joined: Sat Oct 10, 2009 10:30 pm Posts: 189 Location: Perth, WA
Vehicle: 89 Softtop Sierra, 6.5's, 30's
 Posted: Tue Feb 16, 2010 12:31 am |
I have some rust issues.
For the sills I was planning on just cutting rust out and welding in some plate as replacement.
The floor pan I was thinking of cutting out and welding in plate. It was suggested to me just to fibreglass over the top? What do you guys reckon.
Also, the wheel arches are in need of attention. Again, fibre glass or welding?
Any other suggestions (i.e. preventative painting etc) on how to deal with this problem would be welcome.
Sills.
The back, under were the rear door would close shut.
And again.
Wheel arches.
Floor plan.
Coffszook
Joined: Tue Sep 22, 2009 11:30 pm Posts: 117 Location: Coffs Harbour
 Posted: Tue Feb 16, 2010 12:43 am |
a Zook owners worst nightmare !! good luck with it.
_________________ 97 coily, 40 mm coil lift, 29" mt, CB, Music (RI
steak_knife
 Posted: Tue Feb 16, 2010 12:56 am |
New tub mate, by the time you cut all that out you will only have a chassis left.
sbyard
 Posted: Tue Feb 16, 2010 1:02 am |
And if that isn't an option? Lack of tools, space, and know how you see.
steak_knife
 Posted: Tue Feb 16, 2010 1:09 am |
sbyard wrote: And if that isn't an option? Lack of tools, space, and know how you see.
The tub is held on by f*#k all, you wouldn't pay some one to cut that out, it would cost a friggen fortune.
Or you could just tar over it..
hooki
Joined: Mon Jul 21, 2008 11:30 pm Posts: 1785 Location: perth, WA
 Posted: Tue Feb 16, 2010 4:45 am |
dont bother fibreglassing it mate, the rust will just come back. Cutting and welding is defently the way to go. Depends if you have access to a welder and grinder though, plus it will be a good couple of w/e's to get it right. As said above a new tub would be ideal and they arent to hard to change.
_________________ 79' LJ80 (sold) :( 95' & 97' sierra (sold)
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Tue Feb 16, 2010 6:10 am |
Mate that is not so bad, plenty of people fix worse, pull off the side trims and do away with them completely, go buy a $30 Super Cheap Auto grinder, some cutting discs, grinding disks and flapper discs and just get stuck into it. Once it is all cut out then have a go at plating it up, if you don't have a welder rust convert it, paint it with a tar compound like under body deadner and pop rivet sheet metal over it then bog or tar it up depending on where it is. You can get a book from Super Cheap that shows basic, home body repair techniques.
With the bottom of the tailgate opening just grind all that away and weld or rivet a flat piece along there to support the rubber seal.
(I feel like I am on a Super Cheap add)
sbyard
 Posted: Tue Feb 16, 2010 8:54 am |
I know how to weld and grind etc, I jus haven't taken the body off before, or anything close to that. But fair enough if its simple, I'll have a look into it. Cheers for the advice but
[ 8 posts ] |
Users browsing this forum: No registered users and 171 guests
