http://auszookers.com/forum/
high pressure in fuel tank
http://auszookers.com/forum/viewtopic.php?f=5&t=9897
Author:  eldo [ Mon Feb 15, 2010 10:55 pm ]
Post subject:  high pressure in fuel tank
hey guys my fuel tank seems to pressurise itself so much so that when i take off the cap it shoots about 500ml of fuel out at me. any ideas? is there a vent that might be blocked?
Author:  weaves [ Mon Feb 15, 2010 11:22 pm ]
Post subject:  Re: high pressure in fuel tank
If you take off the cover inside the tub that covers the fuel hose, there should be a hose and box setup as a pressure releif setup. that hose is probably blocked
Author:  Brett [ Mon Feb 15, 2010 11:22 pm ]
yes the breather to the charchole chanister.
Author:  31zook [ Mon Feb 15, 2010 11:33 pm ]
haha thats the same as my lwb :D
i wondered if you pressurised the tank would that make it forced fed??? :D
Author:  MrRocky [ Mon Feb 15, 2010 11:37 pm ]
check the charcoal cannister doesnt have water in it as this causes blockages, then blow out the lines with comp air.
Author:  eldo [ Tue Feb 16, 2010 12:15 am ]
so i should give the hoses a hit with air from the charcoal canister end first and see what happens? i dont really want to remove the cover from the tray area, it is spot welded in
Author:  squirezook [ Tue Feb 16, 2010 2:12 am ]
My lwb does the same. Maybe I should look into it as well.
It is worse on a long trip between fill ups
