It is currently Wed Oct 21, 2026 1:37 pm
Post Posted: Thu Sep 22, 2011 9:54 am
gday all im finally putting my zuk up for sale :cry: so i can continue the build on the new zook.
Details as follows:1.6 efi,air locker rear,cromos and locrite front,6.5 gears,engineered $8000 ono,am negotiable
it is a 1989 WT hard top which i have owned for 3 and a half years and 17000kms.It was bought stock as a rock and turned into the rig it is now.It does have dents and it is matt black but it is reliable and looked after and VERY capable
Has 250xxx kms on the clock and 200 000 on the engine.
Engine is a G16B EFI from a 95 vitara,had new water pump,timing belt,cam and crank seals less than 100km ago and oil and filter and air filter 1000kms ago. It has a set of extractors and a 2" exhaust and runs off a VL fuel pump.runs standard engine fan and a 10" thermo for backup but never neede it yet
Reco gearbox 6000 kms ago
6.5 transfer case gears with beefed up arms,a roctoy ring and 35mm transfer lift
3.7 WT diffs with full rebuilds,new seals and bearings etc and new brake pads and shoes recently. Front diff has cromo axles and CVS and a locrite locker with couplers. Rear has a ARB air locker with the larger twin locker and tyre inflator compressor.Also has extended diff breathers
Has 2" ome springs right round which are sagged now,has vs commy wagon rear shocks up front and 2wd hilux rears on the rear.50mm extended shackles and a 2" Just cruising body lift also.
Has Vitara power steering with a jimny pitman arm and a HD old man emu steering damper and a 15" tube style power steer cooler.
Twin stick offroad fuel tank guard protects the fuel tank and home built front and rear bars,sliders and exo cage help boost the confidence :lol: also has weld on diff armor to protect front centre
Tyres are 31x10.5 Maxxis treps on 15x8 f100 sunraysias.Treps still have 10mm tread left and are a awesome tyre.Spare is a 31 at with great tread
Narva 175 spotties and 3x55w rock lights underneath
Everything has been done over the last 15000kms and it is a reliable little rig.
Has NSW rego for 3 and a half months and is engineer approved.
$8000 ono
PM or 0417065008,cheers appsie
Post Posted: Thu Sep 22, 2011 10:05 am
Location? Please haha
Post Posted: Thu Sep 22, 2011 10:39 am
you always forget something haha
sorry is located in TAMWORTH 2340.
Post Posted: Sat Oct 08, 2011 9:12 pm
BUMP
need this gone. pass the word around fellas
negotiable to any serious offers
Post Posted: Sat Oct 08, 2011 9:22 pm
8O again?????
You bin hanging round stockman???? :roll:
Users browsing this forum: No registered users and 24 guests
