It is currently Sat Oct 24, 2026 7:53 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Sun Feb 12, 2012 3:05 pm
ok so I'm cutting down a g16B harness to the engine harness for the conversion into a sierra. I'm confident that I have cut it down to the engine harness per the wiring diagram below. I have highlighted what I have in the harness on the floor.
harness as I have it now
I know I have to run an extra fuse for the injectors so I'll build an extra box for that. I'm wondering what the next step is to make it plug and play? do I need to run any wires to the ignition or are the sierra ignition wires used here? ultimately I would like to have everything done so I just need to connect it to the battery and splice in a few wires (fuel pump vss etc.)
cheers for the help, I'll be doing a full write up on how to cut out the engine harness once I get the engine in an working.
Post Posted: Sun Feb 12, 2012 3:29 pm
oops wring place can a mod move this?
Vehicle: yellow 83 sierra
Post Posted: Sun Feb 12, 2012 4:24 pm
hey mate i took a commodore motor out for a engine transplant a while back now and what i did was use no wiriing diagrams did it all from my knowledge about electrics which was allmost next to none.
when i did it because it was in the car i disconnected the battery and cut the body wiring harness off the engine harness and after every 5 wires i hooked the battery up to see if it would start and now its just engine loom and would start if it had somewhere to bolt the motor onto to fire it up and it will run
Users browsing this forum: No registered users and 50 guests
