Selling my Coily Sierra 97. Have owned for approx 5 years. No expense spared always garaged. Serviced every 6months new oils throughout regularly maintained as required.
The good:
Complete engine rebuild top to bottom 15k ago new front and rear brakes. new HD clutch 15k ago Front and rear main seal replaced 2inch straight through exhaust extractors new air,oil filters replaced alternator and starter approx 4 years ago Stock Green reprayed original factory colour and had body work done - body straight. 325 mud tires fitted rear maxxis 70% front goodyear muddies 40% swivel hubs rebuilt within last 6 months and seals new tie rod links Rear bearing redone checker black sills removable hardtop complete and watertight black steel custom bullbar (brackets fitted to suit body lift) 50mm body lift - professionally installed inc. steering column lengthened strengthened strut towers New 40mm spring and struts installed professionally within last 3 months - steering alligned after Tough Dog RTC steering damper 3 months old underbody painted black TJM snorkel plumbed to carby IPF 800 spoties legally wired Uniden compact 2 way fitted - dash modified and aerial wired to bullbar professionally Pioneer USB headunit, high quality 6x9's custom mounted to tailgate and tweeters in front. Recently replaced speedo, clutch cables. Radiator replaced prior to purchase ARB air compressor and kit including pump kit deflator and all fixings. Replaced front control arms - new bushes. Extended brake lines rear seats very good condition ready to bolt in workshop manual haynes and factory info gearbox tight new sparkpugs, leads, hoses by me. All receipts for all work plus alot more which I have forgotten
The bad: Spots of rust under rear seats - easily fixed front footwells existing rust which has been repaired missing bung front LH footwell rh window needs new winding mechanism - doesnt close completely may need new battery soon heater has stopped working speedo may need adjusting but currently working rear brake light out and front indicator bulb to be replaced
No RWC - rego expires soon but will prob put another 6 months on it.
I am selling as I am moving overseas.
Can provide photos of course PM me and I can email through - please feel free to ask any questions
Users browsing this forum: No registered users and 20 guests
