It is currently Thu Sep 03, 2026 5:34 am
Vehicle: twin cam, twin locked, turbo
Post Posted: Fri Nov 17, 2017 11:20 am
Very regrettably I am offering up my Sierra for sale.
Other projects have forced this decision
I will leave it here for a few days before I offer it to the masses.
PM me, include your number and I will call you back
No nonsense sale. I want $6k
view build thread here viewtopic.php?f=4&t=50904
Located in Lake Macquarie/Newcastle area NSW
1992 Sierra SJ70 Soft top
195000 klm
6 months NSW rego, no inspection for 12 months
NOT engineered
Engine:
Gti swift, running a small turbo from a subaru, top mount intercooler
Wired up with vss, check engine light and diagnostics
Drive line
4.1 diff gears, chromo CV's and axles, auto locker in front diff.
spooled rear diff, diff breathers, 4.9 transfer gears, braced mounts and roctoy ring, transfer raised 40mm
Suspension
Full RUF in front, rear springs all round with leaves mixed to give desired stance and travel.
commodore shocks in front, hilux rear with top mount relocation, bump stops extended to suit
Wheels & Brakes
31 10.5 15 MT on 15x8 rims full size spare
LWB vitara front brakes with extended lines
Body
Custom front and rear steel tube bar work, rock sliders
ATV 4500lb winch hard wired in cab
LED light bar
working scoop to allow air to top mount
fuel tank guard
air compressor mounted in engine bay
rear tail gate storage
some panels now showing battle scars
full soft top in ok condition, no leaks but windows hard to see out of, a press stud missing
Cut down "safari" top
2" body lift
Interior
4 seats, front are ARB, 40ch UHF, alloy bar behind b pillar
Spares
Spare turbo, parts for rear disc conversion axles, sierra front brakes, transfer hand brake
some other small miscellaneous bits and pieces
Does my neck look red in this?
Vehicle: 1987 WT LWB Sierra Styleside
Post Posted: Fri Nov 17, 2017 10:00 pm
Nooooooooo it's going!!!
Post Posted: Fri Nov 17, 2017 10:46 pm
Only if I get the money.
The next one will be better
Vehicle: Vitara 1994
Post Posted: Mon Nov 20, 2017 3:09 am
I would seriously consider bringing here if I had a chance of registering. Even without it would be worth considering. Would be a weapon for the terrain here.
Good luck with the sale!
Users browsing this forum: No registered users and 10 guests
