Print view
Previous topic | Next topic
| Author |
Message |
Boggomobile
Joined: Tue Oct 04, 2011 8:43 pm Posts: 640 Location: Northern NSW
 Posted: Mon Apr 02, 2012 6:58 am |
Hi All,
Sogone, had a better look over the weekend and found 2 better rims that I had previously used as bases for 2 wheel jack stands. Will cut them off, there may be a little divot to be repaired where the welds are but no where near as rusty!
Mrlj2u, yes $20,00 to your Victorian address and $15.00 to your work address as it is in the same state.
_________________ COOL BANANAS!
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Mon Apr 02, 2012 9:32 am |
I'll give ya a call this afternoon mate.
Boggomobile
 Posted: Tue Apr 03, 2012 7:35 pm |
Hi All, Looks like my repurposed LJ wheels are being repurposed again back on to a Suzuki! Attachment: IMGP5409.JPG
sogone
 Posted: Tue Apr 03, 2012 8:31 pm |
Boggomobile
 Posted: Wed Apr 04, 2012 8:44 am |
Hi All, It's alive! It's alive! On ebay at the moment is my LJ80 and Stockman radiator and shroud, below is a photo and link: Attachment: IMGP5417.JPG SOLD, heading south, in winter???
Boggomobile
 Posted: Wed Apr 04, 2012 11:54 am |
Hi All, Tony, was not sure which spring plate that you needed, can you tell me which one in the photo please? Attachment: IMGP5412.JPG
Boggomobile
 Posted: Wed Apr 04, 2012 7:50 pm |
Hi all, ET phone home. On ebay at the moment is my LJ80 Stockman combination switch assembly, below is a photo and link: Attachment: IMGP5415.JPG Did not sell, any offers????? Regards Greg
5ierra
Joined: Tue Mar 09, 2010 10:30 pm Posts: 1645 Location: Ipswich
 Posted: Wed Apr 04, 2012 11:16 pm |
Hey, just requesting any photos of the 1lt surrounds you have. Dibs on the best black pair you have
Boggomobile
 Posted: Thu Apr 05, 2012 9:17 pm |
Hi All, 5ierra, you are in luck, there was a black pair with only one broken tab! Here are some photos: Attachment: IMGP5424.JPG Attachment: IMGP5425.JPG Regards Greg
Boggomobile
 Posted: Thu Apr 05, 2012 10:36 pm |
Hi All, For something different I am going to talk about driveshaft flanges and universals in LJs and Sierras. Attachment: IMGP5423.JPG My experience only goes back to 1974 LJ50s that have 20mm diameter stag type unis (see photo top left). LJ80s used the same flanges and uni baseplates. Then came the Stockman upgrade which used the same flanges and 25mm circlip type uni baseplates. When the first Sierra came out, still with solid driveshafts, the Stockman uni baseplate was still used, but the flanges that they bolted to changed. The flanges on the transfer were used on this model and became obsolete when the driveshafts were upgraded to tubular. At the same time, the transfer used the flange at bottom left of photo which had a bigger spline, also a switch was added to indicate when 4wd was selected (this is the 1.0L switch type that people talk about because it still has a low ratio)! The early switch type 1.0L transfer used the same stud pattern as the Stockman (here is when the unis changed from internal circlips to external circlips) and the later switch type 1.0L transfer with tube type driveshaft had a bigger flange that would later be 1.3L narrow track type. (see middle flange) When the 1.3L Sierra narrow track came out, it used the later 1.0L flanges on the transfer (now with a higher ratio) and the same baseplates and external circlip unis as the last 1.0L model. (Note the later type unis will fit the earlier internal type baseplates) This allows you to interchange between models for ratio changes using the uni as an adapter. Alternately, you can unbolt any switch type transfer flange and bolt up any switch type flange. When the Widetrack came out, bigger transfer flanges and uni baseplates (see photo at right) were used along with 10mm bolts to replace the previous 8mm bolts. However the spline inside was still the same as the first 1.0L switch type transfer giving a few ratio options.
Boggomobile
 Posted: Fri Apr 06, 2012 6:32 am |
Hi All, Fasten your seatbelts. Its going to be a bumpy night! On ebay at the moment is my Sierra softtop spare wheel carrier. Below is aphoto and link: Attachment: IMGP5421.JPG SOLD, pending paymentRegards Greg
Boggomobile
 Posted: Fri Apr 06, 2012 6:39 am |
Hi All, Thet,re here! On ebay at the moment is my 1.0L Sierra new old stock inlet manifold, below is a photo and link: Attachment: IMGP5422.JPG SOLD, at last a job Regards Greg
masterA
Joined: Tue Jan 18, 2011 3:24 am Posts: 976 Location: Perth
 Posted: Fri Apr 06, 2012 3:05 pm |
Damn....you have alot of parts!!!! PM sent
_________________ Fast,Cheap,Reliable-Pick 2 & 3rd is laughable
sogone
 Posted: Fri Apr 06, 2012 7:43 pm |
Boggo for PM! The guys a Suzuki genius!
Boggomobile
 Posted: Thu Apr 12, 2012 8:24 pm |
Hi All, Elementary my dear Watson! On ebay at the moment is my LJ50 2 stroke oil tank, below is a photo and link: Attachment: IMGP5427.JPG SOLD, heading south in winter! Regards Greg
Boggomobile
 Posted: Thu Apr 12, 2012 8:34 pm |
Hi All, Well, nobody's perfect! On ebay at the moment is my LJ Series softtop uprights for hard doors: Attachment: IMGP5428.JPG SOLD, look forward to being in position! Regards Greg
Boggomobile
 Posted: Fri Apr 13, 2012 7:49 am |
Hi All, Here's looking at you kid! On ebay at the moment is my Sierra free wheeling hubs. Below is a photo and link: Attachment: IMGP5436.JPG SOLD, in and out is a great job! Regards Greg
Boggomobile
 Posted: Fri Apr 13, 2012 8:17 am |
You're gonna need a bigger boat! On ebay at the moment is my 1.0L Sierra Jack shaft. Below is a photo and link: Attachment: IMGP5437.JPG SOLD, Just call me the middle man! Regards Greg
Boggomobile
 Posted: Sat Apr 14, 2012 8:20 am |
Boggomobile wrote: Hi All, Attachment: IMGP5412.JPG Tony, was not sure which spring plate that you needed, can you tell me which one in the photo please? Tony, I see what you mean, postage to Lightning Ridge is not cheap!
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Mon Apr 16, 2012 10:53 am |
LJ80 stockman rear tail shafts?
gvzookdriver
Joined: Mon Apr 13, 2009 11:30 pm Posts: 1833 Location: Brisbane
Vehicle: Sold zuk got a Bt50
 Posted: Mon Apr 16, 2012 11:27 am |
did you find any more brake blocks
_________________ bt50 now but still love the zooks
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Mon Apr 16, 2012 5:25 pm |
Boggomobile wrote: ROAR99 wrote: sogone wrote: Haha. Did you just outbid me ya Jew ROAR? looks like it mate,, this is a fucken joke ,, put something for sale on AZ price it and sell it... preety fucken simple!! hes simply usin AZ to drum up sales on hes ebay site.. i understand this has been checked and allowed but a true AZ member would have put it on here first then advertised elsewhere if he,she couldnt sell it.. Hi ROAR99, Firstly, you have stepped up and said your piece, I admire that, I really do! You are and everyone is entitled to an opinion and welcome to express it here. Secondly, Before you step down off your soapbox, could you please enlighten me as to what you think a nearly 30 year old second hand transfer is worth? In fact does anyone else have an opinion on what they think it is worth, feel free to post and let us know? Thirdly, ebay is not (hes) my website! And finally, Listing things on ebay and giving info and a link on AZ is the best way to be fair to everyone! No one is making you bid, you are welcome to and YOU do so as a matter of choice. Remember I am selling parts to anyone who wants/needs them for their project and or rig! Happy to help anyone! Regards Greg I removed the siezed speedo drive from this case today. I only saw the main shaft, front case and speedo drive. The speedo drive gear had been siezed for some time. The drive gear was scolloped from the worm gear on the main shaft spinning against the stationary drive gear. Both parts are useless. The main shaft has some of the heaviest bearing damage I have layed my eyes on. I'm sure ROAR99 can provide some pics. I have no idea what was said between seller and buyer with regards to the condition of the case. But I do know that it would be worth about $50. No more.
_________________ 2013 GV 1998 SV420 ute
ROAR99
Joined: Sat Jul 16, 2011 8:31 am Posts: 190 Location: brisbane
 Posted: Mon Apr 16, 2012 6:23 pm |
Fatzook wrote: Boggomobile wrote: ROAR99 wrote: sogone wrote: Haha. Did you just outbid me ya Jew ROAR? looks like it mate,, this is a fucken joke ,, put something for sale on AZ price it and sell it... preety fucken simple!! hes simply usin AZ to drum up sales on hes ebay site.. i understand this has been checked and allowed but a true AZ member would have put it on here first then advertised elsewhere if he,she couldnt sell it.. Hi ROAR99, Firstly, you have stepped up and said your piece, I admire that, I really do! You are and everyone is entitled to an opinion and welcome to express it here. Secondly, Before you step down off your soapbox, could you please enlighten me as to what you think a nearly 30 year old second hand transfer is worth? In fact does anyone else have an opinion on what they think it is worth, feel free to post and let us know? Thirdly, ebay is not (hes) my website! And finally, Listing things on ebay and giving info and a link on AZ is the best way to be fair to everyone! No one is making you bid, you are welcome to and YOU do so as a matter of choice. Remember I am selling parts to anyone who wants/needs them for their project and or rig! Happy to help anyone! Regards Greg I removed the siezed speedo drive from this case today. I only saw the main shaft, front case and speedo drive. The speedo drive gear had been siezed for some time. The drive gear was scolloped from the worm gear on the main shaft spinning against the stationary drive gear. Both parts are useless. The main shaft has some of the heaviest bearing damage I have layed my eyes on. I'm sure ROAR99 can provide some pics. I have no idea what was said between seller and buyer with regards to the condition of the case. But I do know that it would be worth about $50. No more. so i received a message from boggo saying he has a 1ltr case. as i had posted for a 1ltr case in GOOD CONDITION>> i specifically asked him again if it was in good working order!! hes reply was "YES " just needs some bearings put thru it. ($170 not bad if in g,working order) !!what a fucken understatement!! the only thing useable on the case is gears and outer casings i already orderd rebuild kit to suit and have sold my original t,case before striping this one down. so too far into it to bother asking for money back off this d,head.. only point i want to make is IF U SELL SOMETHING U HAVE NO IDEA WHAT CONDITION IT IS IN,, THEN FUCKEN SAY IT!!
Boggomobile
 Posted: Tue Apr 17, 2012 7:57 pm |
Hi All,
Have just got to the computer and read the posts above, don't think there was room to reply, so I am replying here below. This is the first that I have heard that there was a problem. ROAR, I think you have misunderstood the ebay listing, (has been left sit for a long time, shall I go on.....) At no time did I say the transfer was is good condition, yes I did say that it needed bearings and seals, obvious because you could feel the freeplay. During our phone conversation Rorie, I very clearly expressed that we would not know the true condition until it was apart, I can tell you what I think, but if you want to hear something else, there is not much that I can do about that. Also in our phone conversation, think about it and you will remember, I said that if anything is worn out or broken, I would happily send up the bits you need as I have spares!!!!!!!
Why do you always think the worst and jump to conclusions? Do you need to give the grief? You seemed quite reasonable when we talked on the phone, quite enjoyable to talk to. Is there someting that I am missing?????????????
Fatzook, have I got this right, you are rebuilding it for Rorie? Let us know what you need to make it good, happy to help with the parts that I have. For the record, I was trying to help Rorie and anyone else buying secondhand parts off me, feedback like this makes me wonder why I do it?
Boggomobile
 Posted: Tue Apr 17, 2012 8:01 pm |
tanshi wrote: LJ80 stockman rear tail shafts? Hi tanshi, yes I have LJ80 Stockman rear tail shafts, how many do you want?
Boggomobile
 Posted: Tue Apr 17, 2012 8:03 pm |
gvzookdriver wrote: did you find any more brake blocks Yes, and have PMed you!
Fatzook
 Posted: Tue Apr 17, 2012 8:51 pm |
Boggomobile wrote: Fatzook, have I got this right, you are rebuilding it for Rorie? Let us know what you need to make it good, happy to help with the parts that I have. For the record, I was trying to help Rorie and anyone else buying secondhand parts off me, feedback like this makes me wonder why I do it?
No mate. I have no further involvement with that case at this point in time. I simply extracted the siezed speedo drive so Rory could further strip the case. As for you helping him? Nar mate. At $170 for a case that was in need of a complete rebuild, and condition unkown to you, you didn't help him at all. Still, both parties agreed on the price based on information provided; information that I have no access to, so I'm not here to pass judgement on a deal I know very little about. Its nice of you to offer parts to help make this right. Given I have only seen 30% of the case and its parts, and half of those parts are un-usable, I'd say it will take a fair bit to bring it back to a usable state. It may be easier/ cheaper to give him a partial refund. But that is between you guys. As for bad feedback being discouraging....... well it can be. But you have the opportunity to make good too. Just depends how you want to look at it. Peter
Boggomobile
 Posted: Tue Apr 17, 2012 9:48 pm |
Fatzook][quote-Boggomobile wrote: As for bad feedback being discouraging....... well it can be. But you have the opportunity to make good too. Just depends how you want to look at it.
Peter Hi Peter Always try to be positive, glass is pretty much always half full !!!!
Boggomobile
 Posted: Tue Apr 17, 2012 9:59 pm |
Hi All, Houston, we have a problem! On ebay at the moment is my LJ80 Stockman drivers side mirror, below is a photo and link: Attachment: IMGP5448.JPG SOLD, can't wait to be back in the breeze!
tanshi
 Posted: Wed Apr 18, 2012 8:52 am |
Boggomobile wrote: tanshi wrote: LJ80 stockman rear tail shafts? Hi tanshi, yes I have LJ80 Stockman rear tail shafts, how many do you want? 2 mate. they need to be the ones with the rebuildable unis in them quote on shipping to 4306 in qld to please
Users browsing this forum: No registered users and 55 guests
