It is currently Fri Oct 16, 2026 12:26 pm
Post new topic Reply to topic  [ 600 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 20  Next
Post Posted: Wed Nov 30, 2011 2:08 am
Hi All,
Also on ebay at the moment is my LJ50 carby starting from $20.00, here is a link.
Sold, VIVA 2 strokes! :helloo:
Regards
Greg 0428 789854
Post Posted: Wed Nov 30, 2011 2:10 am
Tony is chasing a set of LJ seats or seat frames. http://auszookers.com/index.php?name=Fo ... ic&t=28159
Post Posted: Wed Nov 30, 2011 2:30 am
Thanks, Greg, I checked with royce and you are ok to continue.
If you could try to keep it all to one thread that would be great though.
I want my old sig back :(
Post Posted: Wed Nov 30, 2011 3:15 am
Greg,
I have merged the two currently active threads into this one, if you could keep all of your parts and ebay links in here that would be great! :D
Post Posted: Wed Nov 30, 2011 9:14 am
Hi All,
Kenny, Tony and I have been exchanging messages, don't have any LJ50 seats and still sorting some blinkers, parkers and tail lights for him.
Ben, changing the name of the thread is fine with me and keeping it all in one is a good idea!
Regards
Greg
Post Posted: Thu Dec 01, 2011 9:46 am
Hi All,
Below is a link to my LJ50 steering linkages starting from $20.00
Sold! Enroute to where the sun sets over the ocean! :woohoo:
Regards
Greg
Post Posted: Thu Dec 01, 2011 11:30 am
Wish you were closer to SA some of those parts I really could have used
Post Posted: Thu Dec 01, 2011 8:52 pm
Hi DR_JOSH,
Australia is getting smaller all the time, I have parts on their way to Melbourne, Perth, Sunshine Coast and Lightning Ridge!
In the new year, people are coming from SA to pick up parts, distance is a small obstacle. Happy to email photos for your perusal.
Regards
Greg
Post Posted: Tue Dec 06, 2011 9:16 am
Hi All,
Below are some links to ebay for new old stock LJ50 gaskets.
Sold, Viva 2 Strokes :woohoo:
Regards
Greg
Post Posted: Thu Dec 08, 2011 9:46 pm
Hi All,
Thought we would ask for some input, I have been grabbing things at random and listing on ebay.
If anyone wants something in particular, I have been emailing them photos and allowing them to make an offer as it is hard to me to value. Sometimes the first offer is fine and the parts are on their way, other times we generally come to an agreement, all good!
Below are some links to parts on ebay at the moment.
Sold, this will keep the tarp taut! :woohoo:
Sold, heading to where the sun sets over the ocean!
:woohoo:
Regards
Greg
Post Posted: Thu Dec 08, 2011 10:05 pm
any good lj50 reed valves??
Vehicle: LJ50V, SJ70
Post Posted: Thu Dec 08, 2011 11:34 pm
Boggomobile wrote:
Hi All,
http://www.ebay.com.au/itm/Suzuki-LJ50- ... 1c21cc3b33
Regards
Greg
LJ50 Jackshaft IS the same size + length as the LJ80 and Stockman, not unique to the 50. In fact, a common upgrade is to change over to the Stockman shaft with larger replaceable uni joints.
If this shaft you have listed is longer than an LJ shaft, then it is for an SJ40 Sierra.
Post Posted: Thu Dec 08, 2011 11:58 pm
Hi All,
Tanshi, there is a set of reed valves, the ones with 4 petals accross instead of 3. One of the mounting plates has been broken, I will take some photos over the weekend and post them early next week.
303zuke, perhaps I have got this wrong? I will have a closer look and edit the listing after that. Thanks for the input.
Regards
Greg
Vehicle: LJ81 Stockman
Post Posted: Fri Dec 09, 2011 7:22 pm
Hi Boggomobile, many thanks for selling me that LJ80 grill. It's arrived safe and sound due to your careful packaging. I am very happy with it !.
Post Posted: Sat Dec 10, 2011 8:45 am
303zuke wrote:
Boggomobile wrote:
Hi All,
Regards
Greg
Hi All,
Have done my homework and edited my listing on ebay!
Post Posted: Sat Dec 10, 2011 9:07 am
Hi All,
Memories can play tricks on you, I knew the LJ50 shaft was longer but was not sure by how much?
Below is a photo depicting the different lengths of Suzuki solid Jack shafts. LJ50 is the longest at 315 between centres (bottom), then LJ80 and Stockman at 306 between centres (middle) and SJ40 (1.0L Sierrra) is the shortest at 268 between centres. The Stockman had many improvements, one of which was 25mm diameter universals held in with circlips.
Have I ever fitted a Stockman shaft to a LJ50?
No, as I have plenty of spares.
Would I?
Absolutely, the lengths are close enough for the ammount of movement between the gearbox and transfer. With the LJ50 Jack shaft also being used in 2 stroke Carrys and allows for wheel travel. This makes the slip joint move in and out more than the difference (9mm).
Regards
Greg
Post Posted: Sat Dec 10, 2011 9:21 am
Hi All,
tanshi, have taken some photos of the reed valves for you. The 4 petal type are the ones that I described and there is a lonely 3 petal type. What exactly are you after, do you need a set?
makes, very happy it arrived safely, always nice to get good feedback!
Regards
Greg
Post Posted: Sat Dec 10, 2011 9:13 pm
Hi Boggomobile, thanks for clearing that up, I have seen that minor length difference before with ones I have had here and assumed that it was a 50/80 thing.
There are also two different length 1litre ones plus a 1litre tube one that comes in Marutis
Post Posted: Sun Dec 11, 2011 10:27 pm
Boggomobile wrote:
Hi All,
Regards
Greg
I have 6 motors which i would like to rebuild at some point, but no reed valves at all for the spare motors
Post Posted: Tue Dec 13, 2011 8:27 am
Hi All,
tanshi, 6 motors is a fair size collection! Am I reading this right, 6 motors and none of them have any reed valves? What happened to them all? Do you have any mounting plates for the 4 petal type as between us, we could make up a set?
Assuming that you are rebuilding motors for other people, have you had trouble getting the middle main bearings?
Regards
Greg
Post Posted: Mon Jan 16, 2012 7:55 pm
Hi All,
Hope everyone had a good Christmas and New Year!
Below is a photo and link to my LJ series (Stockman) will fit all LJ50, LJ80 and Stockman front driveshaft with 25mm replaceable universals on ebay at the moment:
SOLD, ready for four wheeling again! :woohoo:
Regards
Greg
Post Posted: Mon Jan 16, 2012 8:02 pm
Hi All,
Below is a photo and link to my LJ80/Stockman exhaust manifold which is on ebay at the moment:
SOLD, Hopefully this will quieten it down! :hey:
Regards
Greg
Post Posted: Tue Jan 17, 2012 9:00 am
Hi All'
Below is a photo and link too my LJ50 air cleaner assembly on ebay at the moment.
SOLD, got to love the 2 Strokes! :hey:
Regards
Greg
Post Posted: Tue Jan 17, 2012 8:31 pm
Hi All .
Below is a photo and link of my LJ50 parcl shelf on ebay at the moment:
Did not sell, every old Suzuki should have at least a little rust! :blingbling:
Regards
Greg
Post Posted: Tue Jan 17, 2012 8:38 pm
Hi All,
Here is a photo and link to my LJ Series softtop spare wheel carrier on ebay at the moment:
SOLD, don't forget to clip it back on! :woohoo:
Regards
Greg
Post Posted: Tue Jan 17, 2012 9:44 pm
Boggomobile wrote:
Hi All,
Regards
Greg
yep six is correct. I would like to rebuild them but getting bearings is proving very very difficult. i think i only have one 4 petal type reed valve. i have 3 others which doesnt really give me enough reeds
Post Posted: Sat Jan 21, 2012 11:14 am
Hi All,
Tanshi, when you say that you have one 4 petal reed valve, do you mean the complete plate with 8 petals? The reason I ask is I have a full set of 4 petal type, but one of the plates is broken. Maybe between us we could make up a set for you?
Regards
Greg
Post Posted: Tue Jan 24, 2012 9:54 am
Hi All,
Below is a photo and a link to my LJ80/81 Stockman nosecone, grill panel, radiator support panel, whichever is your terminology on ebay at the moment:
SOLD, there is some rust to fix first! :roll:
Regards
Greg
Post Posted: Thu Jan 26, 2012 8:48 am
Hi All,
Below is a photo of and a link to my LJ80 front bumper bar on ebay at the moment:
SOLD, look forward the to being first everywhere again! :D
Regards
Greg :
Post Posted: Thu Jan 26, 2012 11:54 pm
Hi All,
As you have probably guessed, below is a photo and link to my headlight mounting brackets on ebay at the moment
SOLD, ready for night 4 wheeling again :hey:
Regards
Greg
Users browsing this forum: Google [Bot] and 67 guests
