It is currently Fri Oct 16, 2026 6:54 am
Post Posted: Mon Mar 22, 2010 2:03 pm
Item Summary: toyota 4age n sprinter 5 speed n microtec
Condition: Used
Reason for Selling: not needed
Asking Price: 1600 price drop $1300
Delivery Methods: PickUp
Contact Info:
Extra Information:
ITEM:
toyota 4age 16 valve 1.6L motor with toyota sprinter 5 speed geardox
with a microtec computer running the motor
CONDITION:
vgc all was running n working fine till pulled out of car
REASON FOR SELLING:
change of plans put a 4agze n auto into sierra instead
PRICE AND PRICE CONDITIONS:
$1600 complete not seperating
EXTRA INFO:
complete with a tailsharft n starter n alternator n mounts for a 323 ready to go.
Good for corolla or sierra power upgrade
crestmead brisbane southside pick up only can deliver localy
CONTACT:
matt 0402348938 or pm
PICTURES:
can text some
Vehicle: lj81 stockman
Post Posted: Mon Mar 22, 2010 2:50 pm
100kw or 86 kw
the wobble rocks
Post Posted: Tue Mar 23, 2010 2:33 am
ive been told its the 100 kw motor how do u tell
Post Posted: Tue Mar 23, 2010 3:22 am
Tappet covers ! Gen 1 black and blue letters = 96kw
Gen 2 red and black letters =88kw
Gen 3 red letters = 103 kw or so they tell me !! :D
Post Posted: Wed Mar 24, 2010 1:16 pm
these r polished alloy n with a crank angle type dizzy which thay say r in the 100 kw motor
Post Posted: Wed Mar 24, 2010 9:59 pm
ae82 come out with 86kw ae 92 ae94 come out with 100kw sounds like yours is 100kw does it have a cover that goes over the leads with a high bit at one end where the leads come out
the wobble rocks
Post Posted: Thu Mar 25, 2010 12:27 am
cover missing but looks like a gze 1 where the leads go straight up n seal on the cover indervidualy
Post Posted: Fri Mar 26, 2010 12:28 am
if memory serves me correctly blue tops are 87kw.
Post Posted: Fri Mar 26, 2010 2:09 am
price drop $1400
Post Posted: Fri Mar 26, 2010 10:15 pm
??First Generation 4A-GE
The first incarnation of the 4A-GE was seen from 1983 to 1987 under the bonnet of the Japanese market AE82 Corolla, AW11 MR2, AE86 Corolla GT, Corolla Levin, Sprinter Trueno and AA63 Celica. These first generation 4A-GEs can be identified by their silver valve covers with black and blue lettering.
The Toyota 4A-GE was one of the first mass-produced engines to combine a DOHC, multi-valve cylinder head with electronic multi-point fuel injection. The cylinder head is designed to provide a 50 degree valve separation (compared to 22.3 degrees in low output 4A-FE derivatives) and employs belt driven camshafts.
The 4A-GE also brought Toyota Variable Intake System (TVIS). This system comprises a set of butterflies which are used to block the flow of induction air through one of the intake valves during low to mid rpm operation. This is claimed to improve torque. At high revs, the butterfly valves open to allow both intake valves breathe efficiently.
Bore and stroke dimensions are 81 and 77mm respectively and the compression ratio was initially set at 9.4:1. The engine management employs a MAP load input, a distributor and multi-point EFI. Power output of the first generation 4A-GE is 96kW at 6600 rpm and 149Nm at 5200 rpm – very respectable in the early ‘80s.
Post Posted: Tue Mar 30, 2010 1:24 pm
price drop $1300 good running motor n box. p.s i was told off old owner it is a 4agze map sensor motor that was turboed then 2 pass a mod plate in the car i pulled it out of thay remove the turbo n put extractors on in
Post Posted: Tue Mar 30, 2010 7:33 pm
They are power figures relating too japanese emissions standards and 98 ron fuel.
Aussie blue tops where chocked down to 86kw on paper, though testing proved them to be anywhere from 86 to 95.5 kw.
The only exceptions being RWD configured blue tops out of sprinters.
*my information comes from owning a AW11, a AE 82 twincam seca and plus being obsessed by this engine since i was 16... oh and twincam.org*
weaves
Post Posted: Tue Mar 30, 2010 8:15 pm
Fuck I'm Gutted
I Like cat's they make good hats !
Post Posted: Tue Jun 15, 2010 9:11 am
Outside chance! Still for sale?
Post Posted: Thu Jun 17, 2010 7:20 am
agreed.. u still got it?? and if soo any pics ??
Post Posted: Sat Jun 19, 2010 9:04 am
any of the 20 valve engines are Bomb proof and still by technobable some of the most technologically advanced engines still available from Toyota...
And i just relised that it's a 16valve... So ill shut up right about now... :roll:
[Tyrone just backed into Franky Four Fingers' van]
Post Posted: Sat Jun 19, 2010 11:39 am
long gone peeps. He swap this for jeep diffs of all things 8O
Post Posted: Sat Jun 26, 2010 3:36 am
cheers Fatzook for letting us know :)
Users browsing this forum: Google Adsense [Bot] and 49 guests
