It is currently Fri Oct 16, 2026 10:34 am
Post Posted: Tue Jun 01, 2010 11:30 pm
ITEM
17x9" custom made steel comp wheels (x5). 6 stud to suit Toy/Niss. Max offset, 9" backspace :shock:
CONDITION
New. Never fitted with tyres, or to a vehicle.
PRICE
$430 per rim ono
EXTRA INFO
These wheels are made in a similar fasion to the proven 'Fourbys' rims but are possibly a little stronger. They are a one off set that I made for a comp rig that never eventuated.
The centres are 10mm 350FMS, laser cut and spun down to the EXACT ID of the rim surface where they are mounted.
All 5 wheels were built in a jig to ensure that they run true and are safe for use at speed. The wheels have 8mm stregthening rings welded front and rear. They were going to run internal beadlocks, so I am not sure if externals could be made to fit.
All faces are machined flat, but no holes have been drilled for valve stems or beadlock valves, so you can place these where it suits you.
LOCATION
Everton Hills, Brisbane
PICS
CONTACT
Peter 0404 057 383
or PM me
Users browsing this forum: No registered users and 35 guests
