It is currently Sun Nov 15, 2026 5:16 am
Post Posted: Wed Sep 01, 2010 12:05 pm
i have a pair of complete nt diffs in good working condtion front (with tie rod and drag link)
and rear (drum to drum) with really low 4.1 ratio diff centres $220 ono for the pair.
New never used or fitted max headers extractors suit a 1.3L coily sierra, they will clear the tie rod behind the diff.
These can also be used on a leafy too, the flange is the same. $160
1L nt ute fuel tank, perfect condition no dints $90
standard swb vitara soft top coils, $20 a set
glass for sierra driver and passenger doors $20 each
Post Posted: Wed Sep 01, 2010 12:20 pm
are the diffs 1.3 NT?
Post Posted: Wed Sep 01, 2010 12:23 pm
1.0L :cry:
Post Posted: Wed Sep 01, 2010 12:35 pm
bugger i was hoping that they were the maruti jobbies that fit 1.3's
Post Posted: Thu Sep 02, 2010 8:26 am
yep there 1L diffs. Shouldn't you be able to use the ring and pinion in another centre?
Post Posted: Thu Sep 02, 2010 12:19 pm
The SJ40 1L diff crownwheels are about an inch or so (rough estimate) smaller in diameter than 1.3 size SJ diff crownwheels. 1L centres only really fit SJ40's, LJ50's, and LJ80's.
Clearance Hole Technology :P
Post Posted: Thu Sep 02, 2010 12:29 pm
Will these fit in my Turbo Swift? :roll:
Post Posted: Thu Sep 02, 2010 12:36 pm
Yep.
You can install them in the boot, on the back seat, or the passenger side floor :D
Post Posted: Thu Sep 02, 2010 12:38 pm
Yep.
I actually thought about mounting them on the boot lid so at high speed the lid won't try and fall off, some
douche told me the bolts were broken... pfft what does he know. :roll:
Post Posted: Thu Sep 02, 2010 1:19 pm
$150 posted for extactors? in like 2 weeks when i have free coin?
Post Posted: Thu Sep 02, 2010 1:31 pm
Will this fit your taller GTI rubbish? :P
Post Posted: Thu Sep 02, 2010 8:55 pm
i was under the impression that u can use the crown wheel and pinion out of the 1ltr diffs in 1.3 WT diffs can any1 confirm??????
819FKA has Been UNLEASHED
Post Posted: Fri Sep 17, 2010 6:12 am
bump
i also have a bundera front diff housing, no centre or knuckles $100
front and rear bundera radial arms $120 a pair
bundera front axles and cvs $160
In one week, ill have some bits of the coily for sale. Ill post pics and prices soon.
Post Posted: Fri Oct 22, 2010 5:57 am
bump, i still have the bundy gear
I also have a set of 4 rear coil mounts from a vitara $100 for the set.
235x75 r15 maxxis treapadors on 15x8-24 steel rims x5 $700
the spare is like new, only used 3 or 4 times.
bush ranger flare extensions front and rear, trimmed to suit a sierra $80
the front wheels have the same amount of tread, about 70%. the rear wheels have a little less.
1L nt jack shaft, the unis are in good condition $20
I still have the extractors $150 ,
glass for driver and passenger windows $20 each
2 sets of standard vitara swb soft top coils $60 for both.
nt tie rod and drag link $60 for both
nt steering box, it has a full range of movement $50
A second battery system, comes with a tray, prianaha isolator, a large battery and all wiring. $250
Post Posted: Sun Oct 24, 2010 7:09 am
extractors are sold.
I am open to reasonable offers on remaining parts
Post Posted: Sun Oct 24, 2010 12:36 pm
Deep cycle battery? Warranty for under-bonnet? I'll be in Brissie Xmas time if you can hang onto it that long?
Post Posted: Mon Oct 25, 2010 5:57 am
Its not a deep cycle battery. Ill have to look, but i think i may have a warranty on the battery for another 12mths. I will not hold any item unless i receive a 50% deposit. I have been mucked around too much in the past holding onto parts for people that never come to collect.
Post Posted: Wed Oct 27, 2010 6:00 am
bump
Post Posted: Wed Oct 27, 2010 12:35 pm
Thanks for the info. Just been warned researching dual batterries that most of the not-really-expensive ones no longer carry waranties for use in the engine bay.
I'll check back in about 6 weeks when I'm in Brissie, if you still have it then great, if not, oh well.
Post Posted: Tue Nov 02, 2010 7:23 am
im keeping the isolator from the 2nd battery system.
the battery and tray are still for sale $70
i still have the treps for sale.
Post Posted: Mon Nov 15, 2010 6:45 am
the 1L diffs are gone
im posting up two canopies, they are not mine. One is for a lwb the other is a cut down swb hard top.
The LWB canopy, is in ok condtion for something that it is around 25 years old. It comes from a 86 or 87 LWB 1.3L NT. one of the rear windows is cracked and the rubber seals could be replaced it does leak a little bit. It comes with all of the clips. ill upload pics when i get them, $550 ono
the cut swb canopy is in the picture below
it comes with all of the clips and does not leak. $350ono
pm me with your phone number, and ill pass it onto my brother
Post Posted: Mon Nov 15, 2010 7:59 am
any chance of more pics of the swb canopy?
does it go all the way down into tub or just down to the top side of the tray?
Post Posted: Mon Nov 15, 2010 10:06 am
ill get a few pics tomorrow.
it only goes down to the top of the tray.
Post Posted: Fri Nov 19, 2010 6:22 am
the treps and rims are sold.
I still have a steering box $40
ill have a camera tomorrow so ill post up pics of both canopies as they are now.
Here is a pic of the cut canopy when want33s had it
more pics in his build
http://www.auszookers.com/index.php?nam ... sc&start=0
Post Posted: Mon Nov 22, 2010 7:42 pm
tyres still for sale ??
Post Posted: Mon Nov 22, 2010 9:36 pm
That canopy still kickin... :woohoo:
Post Posted: Fri Nov 26, 2010 3:12 am
no they are gone
yeah it is waiting for a new owner
Post Posted: Sat Dec 11, 2010 3:42 am
bump still got canopies and lots of other little bits
Vehicle: Sierra Utey!
Post Posted: Sat Dec 11, 2010 10:06 pm
Still got that fuel tank?
My ute..
Post Posted: Wed Dec 15, 2010 7:31 am
I do.
you have a pm
