It is currently Fri Oct 16, 2026 8:23 pm
Post Posted: Wed Sep 08, 2010 5:32 am
hey zookers
I have for sale
1 set of body lifting blocks for sale they are
solid steel round 75mm x 68mm with a 12mm bolt hole
does not come with bolts
$100 ono for the set open to offers
or trade for a set of 2" spring shackles
Post Posted: Wed Sep 08, 2010 7:52 am
Whay are they to suit?
or just universal blocks??
Post Posted: Wed Sep 08, 2010 8:25 am
Bit steep consider just cruizins is 210 with bolts and postage just a thought mate
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Wed Sep 08, 2010 9:23 am
well i got them for my 85 zook but changed my mind and want 2" spring shackles
but could be use for other 4x4 as long as you dont have more then 10 mounting points on the 4x4 other wise more may be needed
Post Posted: Wed Sep 08, 2010 9:26 am
maybe but these cost me 300 and never been fitted as i changed my mind and its also < ONO >
Post Posted: Wed Sep 08, 2010 11:37 am
Are they 75 high? or 68 high?
If 75 high, they are illegal in QLD.
and if 68 in Diameter they will not fit in the rear or front body mounts, as they will foul on body work.
Post Posted: Wed Sep 08, 2010 12:54 pm
there 75mm high 68mmdia 12mm dia bolt hole
but not hard to change the high as you can cut them down if needed to
what is the legal limt as i have not looked it up
Post Posted: Wed Sep 08, 2010 1:29 pm
50mm in QLD.
But you can't just use a 12mm bolt through the body on a sierra.
The front 2 mounts and rear 2 mounts are 10mm bolts. And the other 6 mounts have a 10mm captive bolt that cannot be removed, so your blocks are completely useless to a sierra owner. I think that the vitara blocks need to be 60mm Dia.
Perhaps try and sell these on a Patrol forum. It sounds like thats what they are made for. :?
Post Posted: Wed Sep 08, 2010 2:01 pm
50mm in QLD.
this is my first zook and not into body lifts and would rather spring lift then body lift
Post Posted: Wed Sep 08, 2010 2:09 pm
Smart man :wink:
Users browsing this forum: No registered users and 35 guests
