It is currently Sat Oct 17, 2026 3:15 am
Post Posted: Tue Nov 02, 2010 8:01 am
add to the list. wt maruti 4.1 centres.front and rear. these are the ones that will fit the 1.3 housings. were removed from a maruti with 89000km to fit 3.7s. worked fine at the time.
$500 for both ends.
hi all, unfortunatly the diffs i have in my project will no longer suit the build so they are up for sale.
Front diff......
wt sierra fitted with 3.9 centre. snake racing hi steer knuckle and draglink, spoa perches in nt width, vented vitara discs and bigger calipers, new kingpin bearings and seals, new wheel bearings all cleaned up and in a fresh coat of paint.
rear diff....
wt sierra, 3.9 centre not fitted atm. skyline/pintara rear calipers ( with handbrake),sierra discs, new larger (width) wheel bearings. this diff is set up for coils on an aframe but mounts will be removed to some degre.
there are no brake lines on the back but if someone takes the whole pakage i'll do the hard lines.
the front is ready to bolt in and go. the rear will need the centre and airlocker fitted and put back together.
REAR arb air locker NEW in box.
really didn't want to go this way but selling to go down the hilux/bundy path. :cry:
$2300 for the lot. am not willing to seperate the locker untill the rest is gone.
pm or 0407927531
Post Posted: Sat Nov 06, 2010 9:25 am
due to the masssive amount of interest, i have decided to add a set of 15x 8 sunnys with a fresh coat of silver 2 pac paint. -2? look pretty deep. maybe -28.
so all of the above plus wheels for $2300. add it up in parts and see it is value. almost ready to go into a stocker and have everything in one go.
rims are gooone
Post Posted: Sat Nov 06, 2010 10:26 pm
I will have Dibs on the rear locker if you separate!
Post Posted: Sun Nov 07, 2010 3:00 am
4th in line :D
Post Posted: Sun Nov 07, 2010 6:23 am
DOH!
Post Posted: Wed Nov 10, 2010 1:44 am
righto, everything $2000. or swap the air locker for a hilux air locker if you have one in surplus.
Post Posted: Sat Nov 13, 2010 2:30 am
adding maruti centres to original post.
Users browsing this forum: No registered users and 87 guests
