It is currently Sun Oct 18, 2026 10:44 pm
Vehicle: My12 Defender 90
Post Posted: Mon Jan 24, 2011 11:16 pm
For sale is 4 235/75 R15 Federal Couragia M/t's they are still 90% or more tread. and have done less than 1000kms.
there on ROH sunnies 15x6's
Offset is 95-100mm from center were they bolt on to the steel lip
The tires alone Retail for $200 and upwards.
Asking $700 ono for rims and tires (can throw in a 235 at on f100 rim as a spare if needed)
please pm me or text/call if interested or want more info.
0423919237
Last edited by the-ninja-kid on Fri Mar 18, 2011 10:11 pm, edited 4 times in total.
Post Posted: Tue Jan 25, 2011 5:30 am
:? -22???
Post Posted: Tue Jan 25, 2011 5:49 am
+22s :o
Post Posted: Tue Jan 25, 2011 5:58 am
appsie wrote:
+22s :o
x 22 :wink:
Post Posted: Tue Jan 25, 2011 6:26 am
I was told -22 when i purchased them. I dont know anything about offset. just what I was told myself.
Post Posted: Tue Jan 25, 2011 6:28 am
If yo fitted backwards that be close to -22..
Post Posted: Tue Jan 25, 2011 8:51 am
so then what does that make them? =22?
Post Posted: Tue Jan 25, 2011 8:57 am
I could be *wrong, but they look like +'s or 0's...
* it has been known to happen.
Post Posted: Tue Jan 25, 2011 7:24 pm
I had a closer look at the wheels just now. the read "289 7 22" then on the other side of the valve stem "6jjx15" and they are ROH wheels.
Post Posted: Tue Jan 25, 2011 7:29 pm
6in wide then..
Post Posted: Tue Jan 25, 2011 7:31 pm
hrm. . okay. changed. i measured them when i put the tires on them and they were closer to 7???
but do these number allude to there offset?
Post Posted: Tue Jan 25, 2011 7:36 pm
Wheel's are measured on the inner bead, not the bit you hammer weight's on to, so the tyre really need's to be off to measure.
Yes the 6jjx15 is 6 wide 15 high & I've forgotten jj :roll:
Post Posted: Tue Jan 25, 2011 7:45 pm
cool. as i said i know nothing about offset or wheels in general really. i was just going by what i was told when i bought them. still unsure of the offset though. . . i was told 22. . . how can i accurately measure this for people?
Post Posted: Thu Jan 27, 2011 6:31 am
also consider some realistic offers?
Post Posted: Fri Jan 28, 2011 10:51 pm
need to sell these to buy 16" tires
Post Posted: Mon Jan 31, 2011 6:24 pm
no one wants to make me an offer? I need em sold. . need the money to put replace my road tires on my vitara. will swap for some good tires for 16" wheels
Post Posted: Mon Jan 31, 2011 6:44 pm
cut a straight object that fits into the rim where you need to measure to
Post Posted: Tue Feb 01, 2011 4:16 am
Do a search for "offset" and you should find what you need, there's a really good write-up somewhere. Basically it's how far off centre the face that bolts to the hub sits.
Post Posted: Sun Feb 20, 2011 5:59 am
Post Posted: Fri Mar 18, 2011 10:12 pm
make a reasonable offer and there yours. Moving house next saturday and need all my suzuki junk gone..
Post Posted: Fri Mar 18, 2011 10:31 pm
if u where told 22, then the guy that sold them to u proberly means +22,
that deffinitly dnt look like a -22.
Offset is reasonble easy once u get used to, 0 offest means your rim centre(where it bolts to the car)
is in the middle of the room, ie. if it where an 8 inch rim there would be 4 inch either side,
so there for if you had an 8 inch rim with a -25 there would be 3 inch back space and 5 inch on the out side,
hopefully this helps a bit,
if u want to measure your off set, put the rim flat on the ground, and measure to the rim center(where it bolts to the car,
then right it up, hopefully ill be able to figure it out,
dodgy brothers mechanical
Post Posted: Fri Mar 18, 2011 11:45 pm
JJ means the rims had rolled bead retaining lips on both side of the rim a j rim only has it on one side
Post Posted: Sat Mar 19, 2011 12:37 am
:P Cheer's!!! :P
Vehicle: Zookless
Post Posted: Sat Mar 19, 2011 1:45 am
So would a "j" rim would be more likely to have the tyre roll off at low pressure :?:
Post Posted: Sun Mar 20, 2011 2:42 am
SOLD
Users browsing this forum: No registered users and 36 guests
