It is currently Mon Oct 05, 2026 5:26 am
Vehicle: Sierra
Post Posted: Mon Dec 20, 2010 7:08 am
I have a tmax ew9000, 9000lbs winch, brand new and still in box.
Location, kew, Melbourne 3101
Pickup required asap
$500
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon Dec 20, 2010 7:12 am
good price! i got mine off ebay for that but a little closer to brisbane
95 Sierra SJ70 TinTop
Vehicle: Sierra
Post Posted: Mon Dec 20, 2010 9:08 pm
Bump
Post Posted: Tue Dec 21, 2010 5:52 am
Dale wrote:
Bump
lol.. you only posted up yesterday. :wink:
255 characters
Vehicle: Sierra
Post Posted: Mon Jan 17, 2011 7:52 am
Bump
Post Posted: Mon Jan 17, 2011 8:30 am
How good are these winchs? Waterproof? Better then Ironman winch?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Vehicle: Sierra
Post Posted: Sat Jan 22, 2011 10:09 pm
Price drop now $550
Post Posted: Sun Jan 23, 2011 12:08 am
whats the overall lenght of the unit?
Vehicle: Sierra
Post Posted: Sun Jan 23, 2011 3:35 am
9000lbs(4300)kgs Rated Single Line Pull5.5HP Heavy Series wound motor 94ft.(28.5m) of 21/64" (8.2mm) galvanized aircraft cable with replacable Clevis Hook.
Rated Line Pull: 9000Lbs.(4300kgs.)single-line
Motor: 5.5hp 12V Series Wound;6hp 24V Series Wound
Control: Remote switch,12'lead (3.7m)
Gear Train: 3-Stage Planetary
Gear Ratio: 218:1
Cluth: Sliding Ring Gear
Brake: Automatic In-The-Drum
Drum size: Diameter 2.5"Length8.8"(64 x 224mm)
Wire Rope: 94',21/64" diameter(28.5m,8.2mm diameter) Fairlead: 4-way fairlead
Remote Control: Included
Recommended Battery: 650CCA minimum for winching
Battery leads: 25,72"(1.83m)
Finish: Black/Dark gray
Weight: 84Lb(38Kg)
Overall dimensions: (L x W x H)21.15" x 6.3" x 8.6"(537 x 160 x 218mm)
Mounting Bolt Pattern: 10.000.015IN x 4.500.010IN(254 x 114.3mm
Vehicle: Sierra
Post Posted: Tue Jan 25, 2011 11:25 am
Price drop $500
Vehicle: Sierra
Post Posted: Sat Feb 05, 2011 10:55 pm
Bump. This is a very good price.
Post Posted: Sat Feb 05, 2011 11:26 pm
yeh but most zook drivers are tighter than a fishes asshole.
Vehicle: Jimny
Post Posted: Wed Feb 09, 2011 5:53 am
hey mate. im not a tight ares but ill give you 400
DONT BUY A GQ! zooks are better. i have both :)
Post Posted: Wed Feb 09, 2011 7:08 am
i have a 6500 tmax which has the same motor with a different gear ratio and
it has been a good thing.
i abuse it a fair bit and it always works, well except when i have a dead battery.
if it was a bit closer i would buy this for my shitbox toyota
Post Posted: Wed Feb 09, 2011 7:29 am
where are these beasts made ?
My Maruti build, Click WWW
Post Posted: Wed Feb 09, 2011 9:03 am
fairly certain that it is seppo land. i will check mine tomorrow
Post Posted: Thu Feb 17, 2011 6:43 am
Pm sent
Vehicle: Sierra
Post Posted: Mon Feb 21, 2011 8:43 am
Bump
Users browsing this forum: No registered users and 58 guests
