| Moreton Bay G16b and Vitara spare parts shop http://auszookers.com/forum/viewtopic.php?f=7&t=19718 |
Page 1 of 2 |
| Author: | royce [ Sat Mar 05, 2011 12:01 am ] |
| Post subject: | Moreton Bay G16b and Vitara spare parts shop |
OK got some useful BRAND NEW quality parts here for sale, some of these bits are items we normally get stung pretty hard for, but cause I am a good shopper I have some bargains All items plus post at normal Australia post rates, we can work it out based on what you want All profits go back to Auszookers for hosting and what not First up, Fram Air filter Fram are a quality product used the world over, these suit any Vitara that uses a ryco A1357 Air filter (screw down lid, but check yours first) $25 each |
| Author: | royce [ Sat Mar 05, 2011 12:17 am ] |
| Post subject: | Re: Moreton Bay G16b and Vitara spare parts shop |
Vitara CV boot x 4 Beck Arnley Brand (Large Japanese company that manufacture lots of replacement parts) Comes with boot, grease, inner and out stainless bands, replacement inner joint circlip Some even have the inner joint large c clip, so if you need one of them I can send that one to you Should fit all 1.6 Vitaras, not sure on later models $15 |
| Author: | royce [ Sat Mar 05, 2011 12:21 am ] |
Oil cap x 1 Stant SO81 model fits my engine Parts Plus wanted $5.59 by the sticker so $5 sounds good |
| Author: | royce [ Sat Mar 05, 2011 12:25 am ] |
Other items I have that I didnt get pics of cause I cant trial fit but know they are correct Rocker Cover gasket suit 16 valve g16b, Beck Arnley Brand, doesnt come with the 4 round seals for the spark plug tubes $20 |
| Author: | royce [ Sat Mar 05, 2011 12:27 am ] |
Ive got access to a lot more of this stuff and other bits and pieces as well so if there is something you are looking for along these lines let me know and i'll see what I can do, some stuff like this saves some money, other stuff not so much. |
| Author: | steak_knife [ Sat Mar 05, 2011 2:22 am ] |
royce wrote: Other items I have that I didnt get pics of cause I cant trial fit but know they are correct
Rocker Cover gasket suit 16 valve g16b, Beck Arnley Brand, doesnt come with the 4 round seals for the spark plug tubes $20 Calliper Hardware, this is the metal spring clips that sit in your Brake Calliper and the pads slide into them, Beck Arnley Brand suits 1.6 wagon brakes $20 (got 2 sets but Stekky already has dibs on one)
| Author: | royce [ Mon Mar 07, 2011 12:33 am ] |
bump so more poeple see my cool pics |
| Author: | Polar_Bear [ Mon Mar 07, 2011 9:41 am ] |
i need some cv boots, a couple of mine are knackered, not sure on qty, will check tomorrow |
| Author: | royce [ Wed Mar 09, 2011 4:07 am ] |
More bumps, parts slowly running out the door |
| Author: | Fatzook [ Wed Mar 09, 2011 4:09 am ] |
royce wrote: More bumps, parts slowly running out the door
Jogging? |
| Author: | Damo [ Wed Mar 09, 2011 4:17 am ] |
Are these regularly stocked items or a one off? |
| Author: | royce [ Wed Mar 09, 2011 4:19 am ] |
Damo wrote: Are these regularly stocked items or a one off?
Will see how long these take to go, if there is enough interest I might get more, but prices could differ by a small amount. |
| Author: | Damo [ Wed Mar 09, 2011 5:17 am ] |
royce wrote: Damo wrote: Are these regularly stocked items or a one off? Will see how long these take to go, if there is enough interest I might get more, but prices could differ by a small amount. That's OK, i'm assuming I will get a significant staff discount
| Author: | royce [ Wed Mar 09, 2011 5:20 am ] |
Ill give you the equiv of 50% of your AZ salary right off the bottom |
| Author: | Damo [ Wed Mar 09, 2011 5:25 am ] |
royce wrote: Ill give you the equiv of 50% of your AZ salary right off the bottom
Make it half my salary and you've got a deal!!! |
| Author: | royce [ Sat Apr 02, 2011 7:05 am ] |
buy this stuff! |
| Author: | steak_knife [ Sat Apr 02, 2011 10:50 am ] |
royce wrote: buy this stuff!
I'll take a set of lead's.... |
| Author: | royce [ Sat Apr 02, 2011 10:54 am ] |
what no cap and rotor |
| Author: | steak_knife [ Sat Apr 02, 2011 11:12 am ] |
royce wrote: what no cap and rotor
Won't fit!!!! |
| Author: | royce [ Sat Apr 02, 2011 8:33 pm ] |
steak_knife wrote: royce wrote: what no cap and rotor Won't fit!!!! thought you had the cool engine like me? |
| Author: | steak_knife [ Sat Apr 02, 2011 9:07 pm ] |
| Author: | royce [ Sun Jul 31, 2011 11:01 pm ] |
bump |
| Author: | swifty_ano [ Sat Sep 03, 2011 3:32 am ] |
Will the airfilters fit the a 1996 suzuki vitara. Screw own lid. Current filter says RAF203. I went to repco and they want $75 for one. |
| Author: | royce [ Sat Sep 03, 2011 8:05 am ] |
mines a 96 with screw on lid and it fits it fine so I guess so |
| Author: | swifty_ano [ Sat Sep 03, 2011 8:18 am ] |
That's cool. Could we make sure it will fit before I buy it? When's a good time to pick one up? |
| Author: | royce [ Sat Sep 03, 2011 8:22 am ] |
No, you can pay for it and if ti doesnt fit ill refund it it is 300x145 outside dimensions of the rubber gasket, youll either be near to that or way off I should be home tomorrow at some point |
| Author: | swifty_ano [ Sat Sep 03, 2011 8:53 am ] |
I had did buy a repco raf196 (don't remember exact number?) And it was about 5mm too small. I'll pm you. |
| Author: | tonka_tuff [ Sun Sep 04, 2011 9:06 am ] |
you wouldnt have any rocker cover gaskets for a g16A would you? |
| Author: | Westie [ Sun Sep 04, 2011 11:15 pm ] |
I am running out of oil filters |
| Author: | rob_macca67 [ Mon Sep 05, 2011 9:36 am ] |
royce wrote: Ignition lead set x 1, was listed as suiting the coil in dissy model but come with a coil lead as well
Standard ignition brand, 7mm silicon leads. I have fitted a set to mine and they are a nice fit and well sized, the plug tubes seal well and overall looks like a nice kit. $70 pm sent re: Leads for a EFI Vit |
