| Coil spacers for the GV. http://auszookers.com/forum/viewtopic.php?f=7&t=23474 |
| Author: | carlos83 [ Sat Jul 02, 2011 12:48 am ] |
| Post subject: | Coil spacers for the GV. |
2 pairs of 15mm spacers for the front (will give 30mm of lift) and I pair of 30 mm spacers for the rear (30mm lift). New, not been installed. $50 for the lot (6 spacers) Pick up from Subiaco WA. Or I will look into the cost of postage at the buyers expense if required. |
| Author: | carlos83 [ Sat Jul 02, 2011 12:52 am ] |
| Post subject: | Re: Coil spacers for the GV. |
Thes are polyurethane. Will only suit models without tapered springs, 98-05. OD 108mm and ID 65mm To be used with existing spring insulators. Fit above spring insulator and body and replace existing spacer on top. |
| Author: | tobeszook [ Sat Jul 02, 2011 1:43 am ] |
do you think they will fit a 97 sj80 mate |
| Author: | Built4thrashing [ Sat Jul 02, 2011 1:50 am ] |
You have PM. I want these. consider them sold if you can post them. |
| Author: | carlos83 [ Sat Jul 02, 2011 3:01 am ] |
Sold pending payment. |
| Author: | Bruce [ Sat Jul 02, 2011 6:39 am ] |
tobeszook wrote: do you think they will fit a 97 sj80 mate
If that's a coily they will sort of fit but I do make spacers to suit the coily. |
| Author: | Built4thrashing [ Sat Jul 02, 2011 6:43 am ] |
Do coily use the same size spacers as the front of a GV. If so i have some 30mm spacers for sale that will fit. Shot me a pm and ill give ya details |
| Author: | Built4thrashing [ Sat Jul 02, 2011 7:50 am ] |
carlos83 wrote: Sold pending payment.
Payment is on its way. Cheers |
| Author: | Bruce [ Sat Jul 02, 2011 8:37 am ] |
Built4thrashing wrote: Do coily use the same size spacers as the front of a GV. If so i have some 30mm spacers for sale that will fit.
No. Altho they are close. |
