It is currently Thu Oct 22, 2026 9:08 am
Post Posted: Thu Jul 14, 2011 2:09 am
Some assorted LJ stuff I've decided I don't want/need. Anything can be shipped if you can convince me its a good idea (pickup preferred, and near Ipswich QLD). All prices are negotiable, if you can convince me its a good idea. I may add a few more bits if I come across them in the next day or so...
Item 1: LJ80/LJ81 rear diff assembly. Non-stockman type, 4.5 22spline diff centre. I have 2 of these, the 2nd ones in a car still, and I haven't had a good look at it yet. Will do if this one sells. $100
I also have numerous 4.5 centres which I will sell for $50 each (some may require rebuilds)
Item 2: 3 Original factory bumper bars. 1 bent LJ50, 1 Good LJ80/81 (has one pin hole of rust through on the passenger side), 1 Good LJ80/81 (with holes drilled in it for a nudge bar, which I can throw in with it if the buyer likes). $50 for the 50 bumper, $80 each for the 80 bumpers.
Item 3: Lots of LJ80/81 (stockman or not, doesn't matter) front axle shafts with 1Litre Sierra CV's on them. Ready to go for a disk brake conversion on your front end. Some have been speedy sleeved due to grooves on the seal surface. $75 each. 2 or 3 have a bit of play..... $50 each for these (they could still be used for a spare, or preferably, use the shaft with a better CV). I also have 1 or 2 shafts with standard LJ CV's on them to suit a factory drum front end.
Item 4: Original LJ50 steel type parcel tray. $50.
Item 5: 2 original LJ81 front springs. 1 original LJ50 front springs. Free, or I will dump them.
Item 1:
Item 2:
Item 3:
Item 4:
Item 5:
Clearance Hole Technology :P
Post Posted: Sun Jul 17, 2011 7:04 am
Bump...
Users browsing this forum: No registered users and 16 guests
