It is currently Sat Oct 24, 2026 2:37 am
Post Posted: Thu Sep 01, 2011 8:56 am
For Sale i have a few panels no longer needed on my truggy build.
1) very straight,good working set of doors.Windows wind up nicely,Windows dont rattle as all the channels still intact and they are very straight with no rust.One has a broken off interior handle(cheap,easy fix) and they both have sheetmetal door skins.Missing mirrors
$250 ono
2) WT front clip, once again very straight and clean. is from a 88.5 model so the wt flare mounts are only riveted on. i should have a set of pretty straight flares to go with the clip,will pick them up when needed.Slight surface rust where battery was but all in all good.
$250 ono
3) Soft top targa bar.Very straight,clean and no rust.Also has little bars that run back off it behind seatbelt mounts and ones forward to windscreen
$150 ono
4) set of 4 rubber flares 65mm wide. All cut to Zuk length,come with screws.not real old at all
$25 ono
5) set of standard 22 spline Wide Track axles and CVs. No longer needed due to running cromos.Good nick,not noisy at all.still greased.
$60
Located in Tamworth nsw 2340. pm on here or text 0417065008 as phone has no speaker lol.Negotiable on price,need it gone
Post Posted: Thu Sep 01, 2011 9:24 am
pm sent
Post Posted: Fri Dec 30, 2011 2:41 am
where are you located?
Post Posted: Fri Dec 30, 2011 3:13 am
Tamworth it says! :crazy: :roll:
Users browsing this forum: No registered users and 67 guests
