| 1992 suzuki vitara G16B block and auto http://auszookers.com/forum/viewtopic.php?f=7&t=25903 |
| Author: | orangeshannon [ Sun Sep 18, 2011 7:11 am ] |
| Post subject: | 1992 suzuki vitara G16B block and auto |
hi i have a 92 G16B block up for sale the head was removed only to be put on another engine but ran fine no problems $300 also G16B head need rebuild in bits and peices at the moment $100 a auto out of a 92 LWB vitara estate $300 G16B EFI inlet manifold with some wiring $100 92 ECU (auto) $100 pm me for better prices Melbounre pick up or could drop off anywhere around melbourne for an extra cost |
| Author: | Hipnoce2 [ Thu Apr 19, 2012 4:20 pm ] |
| Post subject: | Re: 1992 suzuki vitara G16B block and auto |
G'day my names Tyler, I was wondering if you still had the block for sale?? PLEASE EMAIL ME ASAP! at tyler.cuttle@gmail.com |
| Author: | orangeshannon [ Fri Apr 20, 2012 12:05 pm ] |
the parts i have left over is the head with all the bits in a box $50 transfer case in very good condition (the oil was bright red like it just had been serviced but it wasnt) $200 front and rear driveshafts $60 for both or $30 each complete exhaust minus the manifold (in good condition) $50 efi dizzy complete with the 90 degree mount that bolts to back of head with leads $50 aircon pump $100 efi airflow sensor $150 ignition coil (works great) $50 painted metalic red rocker cover been fully sand blasted $20 i would like them gone just taking up room i don't have. pick up from burwood i might also have a few other little bit and peices |
| Author: | 11_evl [ Fri Apr 20, 2012 9:26 pm ] |
Did you have full efi wiring harness?? |
| Author: | stockman [ Fri Apr 20, 2012 10:22 pm ] |
Hipnoce2 wrote: G'day my names Tyler, I was wondering if you still had the block for sale?? PLEASE EMAIL ME ASAP! at tyler.cuttle@gmail.com G'day Tyler. |
| Author: | orangeshannon [ Tue Apr 24, 2012 9:11 am ] |
I also have a 16valve camshaft with came gear on it swell $100 Make me an offer on any of my parts I would like them gone as I have no need for them |
| Author: | tonyevans [ Wed Apr 25, 2012 8:45 am ] |
Hi, I will take the head if you will post to NSW for me? Tony |
| Author: | orangeshannon [ Wed Apr 25, 2012 9:49 am ] |
NOTE THE 16V HEAD WAS CRACKED AWHILE BACK N WELDED UP AND WHEN I TOOK IT TO THE MACHINE SHOP THEY SAID THAT IT CRACKED AGAIN AND HAD GONE SOFT. ALSO F u want the head its just the head including came gear but no cam |
| Author: | tonyevans [ Wed Apr 25, 2012 12:18 pm ] |
OK - PM'd |
| Author: | orangeshannon [ Thu Apr 26, 2012 6:23 am ] |
getting rid of the head without anything on or in it take it you want to need it gone $50 for all the head parts minus cam shaft |
| Author: | orangeshannon [ Fri Apr 27, 2012 12:03 pm ] |
air flow meter 5 pin |
| Author: | orangeshannon [ Fri Apr 27, 2012 12:13 pm ] |
few more parts of pics exhaust in car pic but is not in car anymore red rocker cover camshaft AFM |
