http://auszookers.com/forum/
sold
http://auszookers.com/forum/viewtopic.php?f=7&t=26005
Author:  89_tintop [ Wed Sep 21, 2011 9:06 am ]
Post subject:  sold
all gone
Author:  SLYjoel [ Wed Sep 21, 2011 9:37 am ]
Post subject:  Re: Fs: 2000 jimny transfer case.
Any ideas if the rear shaft is interchangable with a '99 model? Mine has a worn CV and I was told by a diff place that the CV is not servicable or replacable.
Author:  89_tintop [ Wed Sep 21, 2011 9:42 am ]
should be mate... mine has a g13 engine.
But am sure they are all the same up until they went to the push button transfer.. And even then I think they are the same.
Author:  SLYjoel [ Wed Sep 21, 2011 10:03 am ]
If the CV in excellent condition?
I might grab it. Let me do a bit more research on these shafts and I'll let you know.
Author:  89_tintop [ Wed Sep 21, 2011 10:10 am ]
There is no noise or anything. I will have a better idea of condition once I have taken it off and feels what it is like.
Author:  steak_knife [ Thu Sep 22, 2011 6:23 am ]
Same same....
Author:  89_tintop [ Thu Sep 22, 2011 8:48 am ]
Cheers for the confirmation :-) I thought they were the same.
Author:  89_tintop [ Mon Sep 26, 2011 7:07 am ]
Bump
Author:  Bugsta [ Fri Sep 30, 2011 11:22 am ]
Did you confirm what ratios your box is?
Author:  monley [ Fri Sep 30, 2011 11:59 am ]
Some info here mate http://www.bigjimny.com/index.php?optio ... d=75#18202 ....
http://www.auszookers.com/index.php?nam ... ny+gearing
Author:  Bugsta [ Fri Sep 30, 2011 10:18 pm ]
Without knowing weather tintops rig is Auto or Manual, and what year it is, I can't know what he has.
Yeah I don't agree with the bigjimny post by Obarno...
"Using the auto transfer box will give you a reduction in high of 20% and 32% in low. "
A change from a MT case of 1:1 and 2:002 to an AT case of 1.32 and 2.643 is 30% in both. If Zukenutter put in TJgears of 27% and that was too much of a change in high for him, I dare say 30% is going to be the same result for me even with slightly bigger tyres (ZK-235, ME-215) My feeling that if I put 31" rubber on, it would be a nice fit.
Author:  monley [ Fri Sep 30, 2011 10:41 pm ]
Um... It says the year in the tread title....and I am 90% sure its a manual....
If it is too much reduction just swap to 4.1 r@p to try bring it back to standard with this t-case.
Author:  89_tintop [ Sat Oct 01, 2011 1:12 am ]
Yeh mate... To confirm monkey us right. My car is a manual.
I have done the math and it is about 30% reduction in high and a 30% in low.. searched the interweb to see if anyone else has done the same conversion from around the world and was unable to find anyone.
Your more then welcome to come down and do a test fit for comparison. Would be good if it works out like it does (currently its only all talk on yhe net as to what it will be) as it would open up a path for the newer jimny owners
Author:  Bugsta [ Sat Oct 01, 2011 1:32 am ]
2000. Yes, overlooked that.
Changing from 4.3 to 4.1 is a difference of about 5%. Not sure if that would be enough to counter for highway. I really like my rev situation with the current setup, so I think the APIO gears are my only real option
If I was going to do it, I'd want to swap for a later Auto electronic box. Would be too hard to test without the hole in the floor already I reckon :/
Author:  monley [ Sat Oct 01, 2011 1:58 am ]
I rev at 4100@ 100kph with 20% tjgears and 235s .....pm projectzook from twisted 4x4 as he is looking into gears sets for jimnys atm....
Author:  89_tintop [ Sat Oct 01, 2011 4:37 am ]
There is a hole in the floor mate, it ishas a cover over it with 4 screws in it... Just have to remove the floor coverings.
Are you planning on fitting larger tyres?
Author:  89_tintop [ Sat Oct 01, 2011 4:41 am ]
Author:  Bugsta [ Sat Oct 01, 2011 5:59 am ]
Eventually. I'm thinking 31's maybe 33's. With that, a 30% reduction would be nice but I'd still want the APIO 58's I reckon
With bigger tyres brings other stresses on things such as brakes, diffs (and I've wrecked 2 rear pinions already!
Author:  89_tintop [ Sat Oct 01, 2011 8:50 am ]
I redid the math and its about a 30% reduction in high and a 30% in low..
Shit.. 33s would look huge on a jimny. You will need some form of diff upgrade, be it chromos or something.
Author:  monley [ Sat Oct 01, 2011 8:52 am ]
I redid the math and its about a 20% reduction in high and a 30% in low..
http://www.auszookers.com/index.php?nam ... ic&t=26301 :helloo:
Author:  89_tintop [ Sat Oct 01, 2011 9:17 am ]
Seen them ... Very cool ...
Author:  Bugsta [ Mon Oct 03, 2011 8:20 am ]
tintop. How are you calculating the 20% and 30%?
Author:  zukenutter [ Tue Oct 04, 2011 6:09 am ]
Mark III Jimny is 1:1 High Range
Mark II Jimny is 1.3:1
Minus the diff ratio difference
Mark III Jimny diff ratio is 1:4.30
Mark II Jimny diff ratio is 1:4.09
Same equation for Low Range. It's all in a thread somewhere.
Not having a dig but I don't think the sort of reduction the APIO kit offers would suit your driving style.
Author:  Bugsta [ Tue Oct 04, 2011 10:12 am ]
But it might allow me to change it.
Author:  89_tintop [ Tue Oct 11, 2011 6:54 am ]
bump
Author:  zukenutter [ Tue Oct 11, 2011 10:00 am ]
PM sent
Author:  jimnydude [ Mon Oct 17, 2011 7:54 am ]
Post subject:  Re: sold
bloke came to work bought auto t case reakons its mint il get his number
