Long shot but any way I have a set of wt diffs housing I want to swap for some hilux/bundera/60 series diffs
Good:
New rebuilt swivel hubs
New wheel bearings
New front and back disc rotors
Rear disc conversion
Bad:
No centers
Front diff has no axles
Rear disc plate has a few dings from when hiting the axles in Swivel hub may have 1 or 2 felt bolts snapped of inside
Has nt perch spacing but need to be redone as I drilled the locating hole a bit bigger the the leaf spring bolt
If this isn't enough I might chuck in some brand new suzuki oem steering arms that I bought for over $400
Users browsing this forum: No registered users and 39 guests
