It is currently Sat Oct 10, 2026 1:39 pm
Post Posted: Tue Dec 20, 2011 5:45 am
Hi Guys,
I have a windscreen surround with good glass, no rust holes of a LJ50 soft top.
Also still has the wipers and wipermotor attached.
It has some minor dents on the seam (easily covered if you put the seam rubber/plastic stuff around the frame)
Also some surface rusting here and there, but no holes.
I want to swap for a similar condition complete LJ80 one.
0412419619
Can collect within 100klms of Bris.
cheers,
Gerard.
www.facebook.com/pages/MR-THUD/110559122380504
Vehicle: LJ20 LJ50
Post Posted: Tue Dec 20, 2011 5:54 am
so how many hinge holes do you have????? 2 or 3
Camels have nice toes
Post Posted: Tue Dec 20, 2011 6:35 am
Two.,, if you are refering to the LJ50 windscreen itself
Is that good or bad! :)
Vehicle: LJ20 LJ50
Post Posted: Tue Dec 20, 2011 7:54 am
Thats great cause the LJ80 had 2 holes and the LJ50 had three holes.
So you basically just got a LJ80 anyway. If it was a three hole I would have swapped mine for it.
Maybe you just need some LJ80 windscreen hinges part number 63210-73080 or some second hand ones from some where
Post Posted: Tue Dec 20, 2011 12:47 pm
Thanks for your response.
Thats weird. I just checked and I have two other LJ80s here and one has 2 hole and the other has 3.. But the strange thing is that BOTH screens are tapered at the top.
The LJ50 screen i want to swap is basically a rectangle, it doesn't taper at the top. also.. I bought it from a guy who was wrecking his LJ50..
Will have a better look tomorrow in daylight.
BTW it has the hinges fitted.
Cheers,
G.
Users browsing this forum: No registered users and 26 guests
